SQ sub Peerless XXLS 10 slightly used - Car Audio Classifieds!
Old 03-01-2012, 05:54 PM
Active Member
0/11 ssssss967
Default SQ sub Peerless XXLS 10 slightly used
1. Product:Peerless XXLS Sound Quality sub
2. Specs: Peerless 830876 10" XXLS Subwoofer 4 Ohm
This series of state-of-the-art subwoofers continues to enhance Peerless's reputation for delivering the highest quality components for bass. Called the XXLS—for "Xpanded Extra Long Stroke"—these audio transducers add even more excursion to the Peerless XLS line while completely eliminating distortion. The XXLS 10" driver features a strong yet attractive cast frame, reinforced paper cone, flat spider, and generous under-spider venting. The magnet system incorporates multiple distortion-canceling fixtures. Buyout, limited quantities. Specifications: *Power handling: 175 watts RMS/350 watts max *VCdia: 2" *Le: 1.5 mH *Impedance: 4 ohms *Re: 1.7 ohms *Frequency response: 39-2,000 Hz *Fs: 39 Hz *SPL: 92 dB 2.83V/1m *Vas: 0.83 cu. ft. *Qms: 6.79 *Qes: 0.47 *Qts: 0.44 *Xmax: 12.5 mm *Dimensions: A: 10-5/8", B: 9-3/8", C: 6".
3. Description/Condition: Got it new . has around 10hrs time on it. I dont drive much outside work. I have decided to go with 2 eights for install reasons. This sub can handle lots more CLEAN POWER than its rated. I ran roughly 300 on it. This is a well made sub and can use a small box. I just want to do a little something else.
4. Price:$100 :
Old 03-02-2012, 06:24 AM
Active Member
0/11 ssssss967
SPL:92db
that means with right box this sub will be loud and super efficient.
the power ratings ware way conservative.
Parts express specs and reviews:
Peerless 830876 10" XXLS Subwoofer 4 Ohm 299-238
SounDigital SD8000 (Slightly Used) Traxxstar504 Mono Amplifiers 25 08-04-2011 03:23 PM
Slightly lagging here.... READ! TeamPSI (Fix My Speaker) 4 05-02-2011 06:26 PM
Slightly lagging here.... READ! TeamPSI (PSI Car Audio) 1 05-02-2011 06:18 PM
slightly stoopid bobbygilly Off Topic Chat 26 09-02-2010 03:17 PM
Fi BL 18 slightly used! bangin hoe 18" Subwoofers 4 03-30-2010 12:11 PM
