2 Alpine Type Rs-Barely used - Car Audio Classifieds!
Old 04-15-2012, 04:38 PM
mhubbard's Avatar
0/11 ssssss267
Default 2 Alpine Type Rs-Barely used
2 Alpine Type R woofers dual 2 ohm versions. Only owned for 3 months.
10" Dual 2 ohm Type R Subwoofer
Power Handling:
  • Peak: 1800 watts
  • RMS: 300-600 watts
Kevlar reinforced pulp cone woofer
2-Piece Structural Parabolic diaphragm design
Injection molded Santoprene rubber surround
Alpine exclusive High Amplitude Multi-Roll (H.A.M.R) surround for impressive excursion and clean, accurate bass
FEA Optimized progressive NOMEX spider
Radial vented VC head sink
Concealed mount gasket system
Reinforced layer spider integration tinsel leads
Oversized 2-1/2" Voice coil
4-Layer dual voice coil design
Voice coil made from 180C high temperature wire on spiral cut aluminum former
Single-piece cast aluminum frame with Alpine Patent Pending Airflow Management System for efficient cooling
Airflow Management system controls the temperature of the voice coil by directing the air across the heatsink
One sided push terminals make installation and wiring fast and simple
Each terminal accepts up to 8 AWG wire for high power signal transfer
Concealed gasket mounting system hides the screw holes and makes for a clean install
Integrated grill technology allows for a seamless installation of a grill
US Patented Compound Radius Curve (CRC) design with integrated short sleeve configuration
CRC Machined motor structure creates a symmetrical magnetic field for less distortion and improves power handling
High-power, double-stacked strontium magnet structure
Newly redesigned for a 20% depth reduction
Frequency response: 26-400 Hz
Sensitivity: 83 dB
Both are in excellent condition. One has 2 scratches on the surround. They come in the original boxes with instructions and necessary hardware.
$175 shipped for both anywhere in the USA. No trades. They will both be sold together. I will not split up.
02 4-Runner-Alpe CDE-HD148BT-Acntrl 3.2-US Acoustics USX 2100 on JL Audio C5-650-US Acoustics Mike on RF T1 15 @ 34hz
90 300zx-Alpe CDE-147BT-Acntrl 3.1-Dmnd D1 300.4 on Crssfre Separates-Dmnd D3 800.1 on NVX XQW104 @35hz
Old 04-15-2012, 05:37 PM
ThumpinTitan's Avatar
Super User
0/11 ssssss775
Feedback Score: 41 reviews
how much picked up?
Old 04-15-2012, 08:26 PM
LoudCavi's Avatar
0/11 sssss2328
Feedback Score: 31 reviews
fi q 12
2000 Grandam GT
Alpine cda-9886
1/0
gp3k and gp2150
3 93ah c&ds
2 custom hdc3 12s
Old 04-16-2012, 08:59 AM
mhubbard's Avatar
0/11 ssssss267
To the top.
Old 04-16-2012, 11:53 PM
mhubbard's Avatar
0/11 ssssss267
To the top.
Old 04-17-2012, 11:57 AM
mhubbard's Avatar
0/11 ssssss267
Sold. Thanks
new alpine type r vs alpine type r first gen exbar420 General Car Audio Discussion & Questions 6 11-20-2011 08:56 PM
Cheap Alpine Type R's? or Type X's? law112493 Wanting to Buy (WTB) 24 10-03-2011 09:23 PM
FS: 2 12" Alpine Type R Subs Barely Used in Dual Ported Box meazy88 12" Subwoofers 1 06-25-2010 11:21 AM
4 Alpine Type E 12s for a Type R 15? jakobkay Bargain Bin 13 06-01-2010 11:13 PM
