FS/FT RE Audio REX 10 Dual 4 Sub - Car Audio Classifieds!
Old 04-29-2012, 09:35 AM
0/11 ssssss759
Default FS/FT RE Audio REX 10 Dual 4 Sub
10" Dual 4 ohm REX Series Subwoofer
Power Handling:
RMS: 175 watts
Impedance: Dual 4 ohm
Mica filled poly cone woofer
Santoprene rubber surround
Pressed steel basket
FEA Optimized motor structure
Linear Conex spiders
Rubber gasket
High temperature 8-layer copper voice coil
Powerful, single stacked magnet
Sensitivity: 84.7 dB
Mounting Depth: 5"
Authorized Internet Dealer
1-year Manufacturer's warranty
REX 10D4" T/S Parameters:
Electrical Q Value (Qes): 0.39
Mechanical Q Value (Qms): 4.37
Total Speaker Q Value (Qts): 0.36
Free Air Resonance (Fs): 21.5 Hz
Equivalent Compliance (Vas): 75.6 liters
One-Way, Linear Excursion (Xmax): 12 mm
Efficiency (SPL 1W/1m): 84.7 dB SPL
Effective Piston Area (Sd): 322 cm2
DC Resistance (Re): 3.2 ohm
Nominal Impedance (Znom): Dual 4 ohm
Thermal Power Handling (Pe): 175 W
Force Factor (Bl): 15.4
This sub is about a month old, I bought it, mounted it and decided on going with an 8" instead of a 10" in my single cab truck. This sub has never seen power and I have the original box, packing foam, and instruction manual.
$42 shipped ($40 + fees), or trade for the 8" version.
2000 Astro on 20s - Kenwood X595, Audiocontrol Three.1, JL Audio 10W7, Audiopipe APSM-1500, Hifonics Titan TXI6408, Powerbass 4XL 6.5" Mids, DB Drive S3 T1 Tweeters, Optima Yellow Top, Shuriken BT-60
Old 04-30-2012, 08:09 AM
0/11 ssssss759
Bump....will trade for a shallow 8 juch as an REx 8 or JL W1
Old 05-01-2012, 04:24 PM
0/11 ssssss759
bump!
Old 05-02-2012, 01:22 PM
0/11 ssssss759
bump.
Old 05-03-2012, 08:40 PM
0/11 ssssss759
Old 05-04-2012, 08:19 AM
0/11 ssssss759
Bumpp
Old 05-04-2012, 08:13 PM
0/11 ssssss759
bumpbumpbump
Old 05-05-2012, 10:12 AM
0/11 ssssss759
Bump...no interest? I guess I'll try CL
Old 05-06-2012, 06:28 PM
0/11 ssssss759
bump...trades?
Old 05-06-2012, 07:02 PM
0/11 ssssss300
i got an e8v1
Re Audio Rex 8 in Fiberglass Center Console with JL Audio 300/2v2 buttphacekilla Car Audio Packages 6 02-24-2012 06:14 PM
(4) REX 8's and RE Audio mono Amp Stitched Car Audio Packages 17 02-02-2012 01:23 PM
(2) BNIB Re Audio REX-8's, $80 shipped Supergumby5000 8" Subwoofers 6 12-11-2011 04:48 PM
the psycho rex peas247 Car Audio Videos 19 09-29-2009 05:01 PM
Pink Rex! MaTT6387 Build Logs 11 08-11-2009 09:20 PM
