FS: Eclipse 88100TI/SW9102 Minty - Car Audio Classifieds!
Old 05-20-2012, 11:19 PM
Boomsday's Avatar
0/11 sssss1929
Feedback Score: 25 reviews
Default FS: Eclipse 88100TI/SW9102 Minty
Pre-Break-In TSP's
Re = 1.6834 ohms
Fs = 48.1132 Hz
Zmax = 25.4708 ohms
Qes = 0.6235
Qms = 8.8097
Qts = 0.5823
Le = 1.6750 mH (at 1 kHz)
Diam = 193.6750 mm ( 7.6250 in )
Sd =29460.2886 mm^2( 45.6635 in^2)
Vas = 7.1435 L ( 0.2523 ft^3)
BL = 12.4160 N/A
Mms = 188.8582 g
Cms = 57.9396 uM/N
Kms =17259.3613 N/M
Rms = 6.4806 R mechanical
Efficiency = 0.1199 %
Sensitivity= 82.8065 dB @1W/1m
Barley touched, looks mint there is a little spot of oxy on the bottom coils read 3.3 and 3.3
$210shipped
Old 05-20-2012, 11:39 PM
Supergumby5000's Avatar
0/11 ssssss642
where are you located?
Old 05-20-2012, 11:43 PM
0/11 ssssss692
sw model titaniums comes with a quick change assembly ring and have different specs very nice sub though
Old 05-20-2012, 11:46 PM
Boomsday's Avatar
0/11 sssss1929
Alabama
Old 05-21-2012, 02:35 PM
0/11 sssssss96
What was the RMS power on these again?
Old 05-21-2012, 04:13 PM
Boomsday's Avatar
0/11 sssss1929
I was told 750per coil, so depending on application 1-1.5k would be fine
Old 05-21-2012, 05:06 PM
0/11 sssssss96
Yeah I was afraid of that, for some reason I was hoping the 10" was less power hungry because I'm not looking to run that much juice with the next substage.
GLWS
Old 05-22-2012, 06:07 PM
Boomsday's Avatar
0/11 sssss1929
GLWS
I wouldn't call it power hungry, rms only tells a little bit about a sub, im sure u will be hard pressed to find a sub in this power/price range that will be that much better then this one
Old 05-24-2012, 11:44 AM
0/11 sssssss96
Oh trust me, I know how well these subs perform. But I'm limited to 500 watts, which isn't too bad, but I only have .8ft to work with and about 6" mounting depth.
If I wasn't so confined, I would have picked this up long ago.
Old 05-24-2012, 11:27 PM
Boomsday's Avatar
0/11 sssss1929
ohhh
Fs Eclipse SW9102 tc3k101 10" Subwoofers 12 05-06-2012 10:57 PM
FS: Eclipse TI SW9102 x 2 HiloDB1 10" Subwoofers 24 12-21-2011 11:15 AM
Eclipse SW9102 BKNIGHTS 10" Subwoofers 3 09-30-2011 05:41 PM
FS: Eclipse 88100Ti/TC 3HP motor, Fi BL motor and 10" basket bergend2 Speaker Accessories & Parts 60 04-19-2011 02:30 PM
Eclipse SW9102 Audio_phill 10" Subwoofers 12 08-27-2010 06:37 AM
