2 Cerwin Vega V-Maxes dual 2 ohm barely used - Car Audio Classifieds!
Old 06-11-2012, 01:43 PM
mhubbard's Avatar
0/11 ssssss267
Default 2 Cerwin Vega V-Maxes dual 2 ohm barely used
2 Cerwin Vega V-Max 10 inch dual 2 ohm versions
V-MAX series subwoofers, like the VMAX102, has been the most popular, award-winning, series of Cerwin-Vega subwoofers for the last 10 years for many reasons. The series of subwoofers are offered in a 10", 12", and 15" size with each respective size having the option of a Dual 2 ohm or Dual 4 ohm voice coil. They offer a power rating of 1000 watts peak and 500 watts of continuous RMS power making them your daily "ground-pounders". With these many different sizes and impedance options, these woofers offer versatility and a significant amount of bass that is sure to fit anyone's bass needs. The woofers feature a composite polypropylene cone and a wider larger than normal rubber surround for increased excursion level, performance, quality, and strength. The use of O2 Cast technology increases basket strength and lowers basket resonance, which also increases the quality and performance of the subwoofers. The woofers also feature cross-flow window venting that reduces voice coil temperatures and radial contact convex domes that reduce cone flex and minimize distortion. If you want to achieve exceptional low-frequency reproduction that is accompanied by quality manufacturing and amazing value, look no further than the Cerwin-Vega VMAX series subwoofers.
  • 10" Dual 2 Ohm VMAX Series Subwoofer
  • Power Handling:
    • Peak: 1000 watts
    • RMS: 500 watts
  • Impedance: Dual 2 ohm
  • Polypropylene composite cone woofer for the perfect weight to strength ratio
  • Wide rubber surround
  • Radial contact convex domes design minimizes cone flex and reduces distortion
  • Window framed venting draws cool air directly to the voice coil for increased power handling
  • Dual linear rolled spiders for unmatched assembly cone control at all volumes
  • 2.5" Dual 2 ohm high-grade voice coils
  • O2 Cast technology increases basket strength while lowering basket resonance for increased performance and quality
  • Sensitivity: 83.1 dB
  • Cutout Dimensions: 9-1/4"
  • Mounting Depth: 6-3/8"
  • 1-year Manufacture's warranty
Purchased brand new from dealer, used for 1 month, then stored in the shed for 3 years in boxes. 9/5 out of 10 condition.
$160 shipped anywhere in the United States
02 4-Runner-Alpe CDE-HD148BT-Acntrl 3.2-US Acoustics USX 2100 on JL Audio C5-650-US Acoustics Mike on RF T1 15 @ 34hz
90 300zx-Alpe CDE-147BT-Acntrl 3.1-Dmnd D1 300.4 on Crssfre Separates-Dmnd D3 800.1 on NVX XQW104 @35hz
Old 06-11-2012, 06:41 PM
Matt3824's Avatar
0/11 sssss3754
160 shipped for both?
If so, amazing deal for some vega goodness
Old 06-11-2012, 07:24 PM
mhubbard's Avatar
0/11 ssssss267
Yes it is $160 for the pair.
Old 06-11-2012, 09:18 PM
0/11 sssss1137
I has three motors if someone is looking for more. I dunno if Vega recones or has recones for these. May help with sale if someone else. Glws op
2012 jeep wrangler unlimited
Pioneer avhx4600bt-Realm components-Focal coax-Ppi p.9004-Rd d9-2 Northstar nsb130
Old 06-12-2012, 08:30 AM
mhubbard's Avatar
0/11 ssssss267
Thanks
Old 06-12-2012, 08:32 PM
mhubbard's Avatar
0/11 ssssss267
The woofers are sold.
Cerwin Vega Vega 154's!!! 1kw, svc, 15" with ORIGINAL mounting hardware! o. l. t. 15" Subwoofers 12 04-23-2012 10:25 PM
cerwin vega stroker old school 15" 4 ohm psychoacoustics 15" Subwoofers 16 07-27-2010 10:52 AM
WTB 15" Cerwin Vega VMAX dual 4ohm coefamily Wanting to Buy (WTB) 2 05-08-2010 06:25 PM
[SOLD]$75 shipped!!!! Cerwin Vega Vega 124 nismos14 12" Subwoofers 58 09-30-2009 11:01 PM
