PAIR OF MINT RE AUDIO SE 10s - Car Audio Classifieds!
Old 06-28-2012, 10:45 AM
mhubbard's Avatar
0/11 ssssss267
Default PAIR OF MINT RE AUDIO SE 10s
2 RE AUDIO SEs dual 2 ohm models with boxes
  • Nominal Impedance -Znom: Dual 2 ohm
  • Thermal Power Handling -Pe: 600 W
  • Force Factor -Bl: 17.7
  • Electrical Q Value -Qes: .46
  • Mechanical Q Value -Qms: 4.4
  • Total Speaker Q Value -Qts: .42
  • Free Air Resonance -Fs: 26.6 Hz
  • Equivalent Compliance -Vas: 31 liters
  • One-Way, Linear Excursion -Xmax: 18 mm
  • Efficiency - SPL 1W/1m: 83.2 dB SPL
  • Effective Piston Area -Sd: 310 cm^2
  • DC Resistance -Re: 2.8 ohm
  • Mounting Depth - 6”
  • Mounting Hole Diameter - 9.25”
  • Overall Diameter - 11”
  • Bolt Hole Circle - 10.125”
  • Motor Width - 6.25”
  • Motor Depth - 3.25”
  • Basket Depth - 2.75”
  • Displacement - .14 cu. ft.
  • Weight - 20 lbs.
  • Dual Composite 2-piece Cone
  • Rubatek Foam Surround
  • Cast Aluminum Basket
  • Tork-Tite Terminal
  • 3" 4-layer Aluminum Voice Coil
  • FEA Optimized Motor Structure
  • Triple Stack Maganets
  • Progressive Spiders
  • Wrap around Rubber Gasket
Mint 9.5/10 if not better
$250 shipped in United States only. No trades
02 4-Runner-Alpe CDE-HD148BT-Acntrl 3.2-US Acoustics USX 2100 on JL Audio C5-650-US Acoustics Mike on RF T1 15 @ 34hz
90 300zx-Alpe CDE-147BT-Acntrl 3.1-Dmnd D1 300.4 on Crssfre Separates-Dmnd D3 800.1 on NVX XQW104 @35hz
Old 06-28-2012, 06:41 PM
0/11 ssssss500
great subs im trying to get rid of some of these too. glws
Old 06-28-2012, 06:50 PM
mhubbard's Avatar
0/11 ssssss267
Thanks. Good luck to you also.
Old 06-29-2012, 05:06 PM
mhubbard's Avatar
0/11 ssssss267
Bump it up.
Old 06-30-2012, 09:41 AM
mhubbard's Avatar
0/11 ssssss267
$240 shipped
Old 07-01-2012, 03:14 AM
Jesseland's Avatar
0/11 ssssss129
Wish i had the cash, i'd snag these in a heartbeat. Tryin to sell 2 SA 8's V.1 locally, if i do ill let you know
Amp: AQ1200D
Sub: 2 Sundown Audio SD 10's D2
Box: 2.4 CF tuned to 35hz
Batt: XS Power D3400 in rear. Shuriken BT-35 up front
Head: Pioneer AVH-X4500BT
4 Channel Amp: MB Quart ONX4.60
Old 07-01-2012, 03:44 PM
mhubbard's Avatar
0/11 ssssss267
Ok will do.
Old 07-02-2012, 02:41 PM
mhubbard's Avatar
0/11 ssssss267
Bump it up.
Old 07-02-2012, 10:16 PM
0/11 sssssss40
Default Alaska
If you can do that price for them pair shipped to 99669 pm me
WTB: New/mint pair of 8s or 10s Supergumby5000 Wanting to Buy (WTB) 3 06-06-2012 06:24 PM
3 powerbass 3xl 10s dual 1 ohm mint jamesG 10" Subwoofers 3 05-29-2012 08:22 AM
Pair of OZ Audio Matrix Elite 10s (D2) The_Grimy_One 10" Subwoofers 6 01-08-2012 01:07 PM
FS: 2) Very mint JLW7 10s sleepingciv 10" Subwoofers 17 08-10-2011 04:00 PM
Dayton Audio 10s pair 60 shipped. New NVR2LO 10" Subwoofers 3 01-17-2009 06:16 PM
