2 10inch RE Audio SE PRO's - Car Audio Classifieds!
Old 01-09-2013, 02:18 PM
mhubbard's Avatar
0/11 ssssss267
Default 2 10inch RE Audio SE PRO's
2 10 inch RE Audio SE PRO subwoofers. They are both dual 2 ohm subwoofers. These are identical to the original RE Audio SE subwoofers. They come with the instructions and everything else.
Mounting Depth - 6.4 inch
Mounting Hole Diameter - 9.3 inch
Overall Diameter - 11 inch
Bolt Hole Circle - 10.1 inch
Motor Width - 7.3 inch
Motor Depth - 3.4 inch
Basket Depth - 2.94 inch
Displacement - 0.14 cu. ft.
Weight - 21 lbs.
T/S Parameters
10"
  • Electrical Q Value -Qes: 0.46
  • Mechanical Q Value -Qms: 4.4
  • Total Speaker Q Value -Qts: 0.42
  • Free Air Resonance -Fs: 26.6 Hz
  • Equivalent Compliance -Vas: 31 liters
  • One-Way, Linear Excursion -Xmax: 18 mm
  • Efficiency -SPL 1W/1m: 83.2 dB SPL
  • Effective Piston Area -Sd: 310 cm^2
  • DC Resistance -Re: 2.8 ohm
  • Nominal Impedance -Znom: Dual 2 or 4 ohm
  • Thermal Power Handling -Pe: 600 W
  • Force Factor -Bl: 17.7
Barely used 9/10 immaculate condition
$250 shipped. No trades just cash only. Will only be shipped within the United States.
02 4-Runner-Alpe CDE-HD148BT-Acntrl 3.2-US Acoustics USX 2100 on JL Audio C5-650-US Acoustics Mike on RF T1 15 @ 34hz
90 300zx-Alpe CDE-147BT-Acntrl 3.1-Dmnd D1 300.4 on Crssfre Separates-Dmnd D3 800.1 on NVX XQW104 @35hz
Old 01-09-2013, 07:38 PM
mhubbard's Avatar
0/11 ssssss267
Bump it up.
Old 01-09-2013, 10:17 PM
mhubbard's Avatar
0/11 ssssss267
Bump it up.
Old 01-10-2013, 08:09 AM
mhubbard's Avatar
0/11 ssssss267
Bump it up.
Old 01-10-2013, 08:43 PM
mhubbard's Avatar
0/11 ssssss267
Bump it up.
Old 01-12-2013, 08:51 AM
mhubbard's Avatar
0/11 ssssss267
Bump it up.
Old 01-12-2013, 08:33 PM
mhubbard's Avatar
0/11 ssssss267
To the top.
Old 01-12-2013, 10:07 PM
0/11 sssssss33
I'm shocked these haven't sold. Great subs and a damm good price shipped. Wish I had the cash.
DEH 80 PRS, ESX Q120.4, Q275.2, ScanSpeak D3004/6020-00 , ID OEM, SSA Icon, Knu Krystal
Old 01-13-2013, 12:12 AM
mhubbard's Avatar
0/11 ssssss267
Thank you.
Old 01-13-2013, 10:14 PM
mhubbard's Avatar
0/11 ssssss267
Back up to the top.
Why are Diamond Audio Hex Pro's so hard to find online? Krieger88 General Car Audio Discussion & Questions 7 04-17-2012 09:05 PM
2-Crunch GP 3000 Pro's 6KW sqcrewcab Mono Amplifiers 7 03-29-2012 01:06 AM
box pro's please help with port mod. slowpoke General Car Audio Discussion & Questions 4 10-26-2011 09:38 PM
[SOLD] Diamond Audio D9 10inch AlanHall 10" Subwoofers 10 02-22-2010 03:40 PM
