JL Audio 10W6v3 with Grill - Car Audio Classifieds!
Old 02-03-2014, 10:07 PM
0/11 sssssss85
Default JL Audio 10W6v3 with Grill
JL Audio 10W6v3 with matching grill
Nominal Diameter 10.0 in / 250 mm
Overall Diameter (A) 10.5 in / 267 mm
Mounting Hole Diameter (B) 9.02 in / 229 mm
Bolt Hole Circle (C) 9.86 in / 250 mm
Magnet Diameter (D) 6.3 in / 160 mm
Required Pole Vent Clearance 0.50 in / 13 mm
Mounting Depth (E) 6.89 in / 175 mm
Driver Displacement 0.078 cu ft / 2.1 L
Net Weight 20 lb / 9.1 kg
Free Air Resonance (Fs) 30.12 Hz
Electrical Q (Qes) 0.543
Mechanical Q (Qms) 9.228
Total Speaker Q (Qts) 0.513
Equivalent Compliance (Vas) 0.821 cu ft / 23.25 L
One-Way Linear Excursion (Xmax)* 0.75 in / 19 mm
Reference Efficiency (no) 0.11%
Efficiency (1 W / 1 m)** 82.7 dB SPL
Effective Piston Area (Sd) 49.303 sq in / 0.0318 sq m
DC Resistance (Re)*** 6.452
Like New and Squeaky Clean Condition
This thing is massive and can handle a tremendous amount of power. Definately the best sounding sub I've ever heard.
Used for about 3 months in a spec sized box with a 600 watt JL Audio amp crossoed over at 80 Hz. I just cant fit it under the back seat of my truck as planned so I must seek a shallower sub. My loss.
Comes WITH the 10" grill and origional box and packing material.
$300 plus Ship
SA 8 grill KTMrida4life (Sundown Audio) 7 06-26-2012 07:27 PM
This grill for my 200 murph General Automotive Chat 5 03-28-2012 03:50 PM
Looking for a grill for my subwoofer porksoda General Car Audio Discussion & Questions 1 06-30-2011 12:02 AM
My new grill MopaRBumpiN General Automotive Chat 11 03-05-2011 09:47 PM
sub grill question 05RED3 General Car Audio Discussion & Questions 2 06-17-2010 11:36 PM
