RE Audio SX 10' Subwoofer - Car Audio Classifieds!
Old 01-31-2016, 06:22 PM
0/11 ssssss160
Talking RE Audio SX 10' Subwoofer
  • Nominal Impedance -Znom: Dual 4 ohm
  • Thermal Power Handling -Pe: 1000 W
  • Force Factor -Bl: 21
  • Electrical Q Value -Qes: .29
  • Mechanical Q Value -Qms: 4.3
  • Total Speaker Q Value -Qts: .27
  • Free Air Resonance -Fs: 30.7 Hz
  • Equivalent Compliance -Vas: 21.8 liters
  • One-Way, Linear Excursion -Xmax: 22 mm
  • Efficiency - SPL 1W/1m: 85.2 dB SPL
  • Effective Piston Area -Sd: 310 cm^2
  • DC Resistance -Re: 1.9 ohm
  • Mounting Depth - 6”
  • Mounting Hole Diameter - 9.25”
  • Overall Diameter - 11”
  • Bolt Hole Circle - 10.125”
  • Motor Width - 6.5”
  • Motor Depth - 3.25”
  • Basket Depth - 2.75”
  • Displacement - .15 cu. ft.
  • Weight - 23 lbs.
  • Dual Composite 2-piece Cone
  • Rubbertek Foam Surround
  • Cast Aluminum Basket
  • Tork-Tite Terminal
  • FEA Optimized Motor Structure
  • Triple Stack Maganets
  • Progressive Spiders
  • Wrap around Rubber Gasket
Used- In good condition. .
$130.00 plus shipping
Old 01-31-2016, 08:42 PM
0/11 ssssss375
Are you sure it has a 8 layer coil I'm pretty sure the SX only has a 4 layer and the SXX are 8 Layer.
The Following User Says Thank You to MG Man For This Useful Post:
Doola36 (01-31-2016)
Old 01-31-2016, 10:29 PM
0/11 ssssss160
Thanks bro but Im not for sure if its a SX or a SXX. I just know its different than the SX with the rubber around the boot that I had years ago...
Audio Technix subwoofer FocusOn20s eBay 2 10-01-2013 10:41 AM
Massive Audio subwoofer Vinnyrsxs General Car Audio Discussion & Questions 7 03-15-2011 09:37 PM
JL Audio 15W0 Subwoofer JOSEPHKEMP General Car Audio Discussion & Questions 1 09-03-2009 11:33 AM
diamond audio D6 10'' subwoofer 12voltz+- 10" Subwoofers 3 10-16-2008 04:40 PM
MA AUdio HK 15X2 subwoofer SPL Guru Car Audio Product Reviews 4 10-16-2008 07:56 AM
