DSS Ethos 10's - Car Audio Classifieds!
Old 02-01-2016, 03:00 PM
andy75's Avatar
0/11 ssssss788
Default DSS Ethos 10's
Two (2) DSS Ethos 10's. Dual 2 OHM
The Ethos, was designed with two goals in mind. Tight articulate bass and the ability to work in small vented enclosures.
A stiff high pressure kraft fiber reinforced cone with a multi-layer foam surround is used to accommodate the 32.5mm of one way xmax. To handle the 2,000 watts of recommended power necessary to push the cone to xmax a rugged USA made3 inch 4 layer flat aluminum wire coil wrapped on a black anodized aluminum former is used. To ensure music is tight and articulate four eight inch true progressive spiders are utilized along with a FEA optimized 50 pound motor structure. All production samples are tested with a Klippel analyzer to verify parameters and ensure product performs as designed.
FEATURES
2,000 WATT RMS RATED
TRIPPLE STACK 8.6 INCH OD MOTOR STRUCTURE WITH BLACK CHROME FINISH
FOUR PROGRESSIVE SPIDERS WITH WOVEN TENSIL LEADS
HIGH PRESSURE KRAFT FIBER REINFORCED CONE
MULTILAYER FOAM SURROUND
WRAP AROUND RUBBER GASKET
USA MADE 3 INCH 4 LAYER FLAT ALUMINUM COIL ON BLACK ANADIZED ALUMINUM FORMER
DUAL 1 OR 2 NOMINAL IMPEDANCE VOICE COILS
SATIN BLACK CAST ALUMINUM BASKET
T/S PARAMETERS
Re3 ohms
LeTBA
QmsTBA
QesTBA
QtsTBA
FsTBA
MmsTBA
CmsTBA
BL21.43 t/m
VasTBA
SPLTBA
Xmax32.5 mm
Power2,000 Watts
Perfect mechanical and working order. A few slight blemishes that I believe I have well documented in pics.
$600 plus shipping for the pair. They will ship in a 13x13x13 box and weigh 65 pounds. Shipping from 32071
Old 02-01-2016, 03:03 PM
andy75's Avatar
0/11 ssssss788
More Pics.
Dual 2 ohm coils
Old 02-02-2016, 04:46 AM
andy75's Avatar
0/11 ssssss788
Bump.
Old 02-02-2016, 03:16 PM
andy75's Avatar
0/11 ssssss788
Bumpers
Old 02-03-2016, 05:30 AM
andy75's Avatar
0/11 ssssss788
Topside
Old 02-03-2016, 08:40 AM
andy75's Avatar
0/11 ssssss788
Would trade for 2 sundown X8's and cash.
Old 02-03-2016, 05:48 PM
andy75's Avatar
0/11 ssssss788
Bump.
Old 02-04-2016, 10:40 AM
andy75's Avatar
0/11 ssssss788
Bump.
Old 02-05-2016, 06:14 AM
andy75's Avatar
0/11 ssssss788
Bumps
Old 02-05-2016, 06:38 PM
andy75's Avatar
0/11 ssssss788
Or best offer. Lol
Dss ethos help mr505 General Car Audio Discussion & Questions 4 12-21-2015 07:54 AM
2 12 dss ethos metered SPL Addict Direct Sound Solutions 20 04-15-2015 01:53 PM
Few DSS Ethos Videos SWIFT Direct Sound Solutions 10 02-07-2015 09:17 AM
12" DSS Ethos D2 spec134 Craigslist Deals 2 12-13-2014 07:37 PM
A few DSS Ethos vidoes (second try) SWIFT Car Audio Videos 15 12-06-2014 07:00 PM
