4 subs in ported box cheap - Car Audio Classifieds!
Old 01-03-2010, 01:50 AM
Z06 Tony's Avatar
0/11 sssssss78
Default 4 subs in ported box cheap
1. Product: 4 Infinity Kappa 100.1se subs in a ported box(SUV only)
Most likely gonna be too long for anything else. Also can be cut in half for 1 good shorter box w/2 subs for $60. Alraedy did that to 1 of them for a hatch system.
2. Specs: Specifications:Kappa 100.1SE
Power Handling Peak:800WPower Handling RMS:200WSensitivity:93dBFrequency Response ( 1.5dB):25Hz-250HzFrequency Response ( 3dB):25Hz - 250HzMounting Depth:5-1/16"
kappa /100.1DVC
10" dvc Subwoofer
For suggested enclosures check out the downloadable Box and Parameter sheet
Configuration: 10"
Power Handling: 250W RMS
Sensitivity: 93dB 2.83V/1m
Frequency Response: 25 - 250 Hz
Co-Injection Molded Cones bond the cone to the surround during the molding process, eliminating the glue joint.
Mounting Depth: 5.07"
Gold-plated five-way binding posts are used to provide the best possible amplifier connection.
Nominal Impedance: 4 ohms
Fs (Hz): 31.91
Qts: 0.41
Vas (liters): 50
Xmax (mm): 7.43
[email protected] (mH): 2.43
All Kappa subwoofers utilize a large flared and vented polepiece to facilitate voice coil cooling and minimize turbulence
This is a HUGE ported box with 4 subs in it. I used it in a wall with 2 other for a total of 12 subs. I was running them with 3 MA Audio HC4002 amps. The subs were entered in 4 unsanctioned events and won all 4 and they were hardly used cus you could not listen to them for music. Also was not in my DD so the vehicle mostly sat. Have not been used in over 5 years or more. Built the wall for the comps only. I know Infinity is like a Geo Metro around here but if you want cheap bump and have room for the box, it is a good deal. Dont remember what it was all tuned for or the specs. These subs were very popular back in the day. I will measure it Sun and add that to the desc.
$100 for the box and 4 subs. Local P/U only. I know this is a longshot cus there are not alot of members close to Roch NY but I figured I would try here before CL.
(2) Soundstream SPLX-154 Subs CHEAP, ending 12 hours! BlackWaterOp Bargain Bin 2 06-11-2009 12:20 PM
anyone know of any good cheap subs that handle around 1000 rms got160s? General Car Audio Discussion & Questions 20 05-23-2009 03:35 PM
2 15'' L7s in ported box nyckid718 15" Subwoofers 5 11-25-2008 06:55 PM
FS: Tons of stuff, mostly subs CHEAP nismos14 Speaker Accessories & Parts 4 10-03-2008 01:33 PM
