FS...(2) DD 1510t's - Car Audio Classifieds!
Old 08-05-2010, 10:12 AM
0/11 sssss1642
Default FS...(2) DD 1510t's
dd 1510t's
bought last year and used very little
These are my friends subs, and I will attest for them
d4's
Series 1500
Voice Coil Diameter 2.0"
Magnet Weight 120 oz
Power Handling RMS/Peak 500/1800
Suspension 55 mm
Nominal Impedance S4.0 Ohm / D4.0 Ohm
DC Resistance 3.4 Ohm
Model 1508 1510 1512 1515
Rec Box (cubic ft) 1 1.5 2.5 4
Port Area (sq in) 16 24 40 64
Port Length (inches) 24 23 22 21
Woofer Diameter 8" 10" 12" 15"
Free Air Resonance
30 Hz 27 Hz 25 Hz 24 Hz
Qts 0.38 0.45
Qes 0.41 0.5
Qms 4.52 4.61
Vas 44.3L 102.8L
Sensitivity 85.5 dB 86 dB 87 dB 89dB
Shipping Weight 16 lbs 16 lbs 17 lbs 21 lbs
they are both used very little
1 is 9/10 overall, just cuz its used
the other was shipped from dd with a cracked basket from torquing down the basket screw too much, it still works, maybe jb weld would fix and be good to go
$125 shipped for good one
$90+shipping for bad basket one
Old 08-05-2010, 12:16 PM
rocksolid84's Avatar
0/11 sssss1869
the broken one needs a basket>>>
THE DARKNESS IS MY PEACE...
I ONLY BANG MIDGET STRIPPERS THEIR HALF PRICE
Old 08-05-2010, 02:28 PM
0/11 sssss1642
maybe, idk...it moves fine right now, so maybe some jb weld could fix it up. Its a shame cuz the sub was barely used, and we noticed it after pulling the sub
Old 08-05-2010, 02:34 PM
0/11 sssss1869
im stuck theres sa-8 and true bass 8 and 1508 ands 1510 all 4 sale
at the same time damn what do i do...
Old 08-05-2010, 02:39 PM
0/11 sssss1642
depends what you can all fit I guess
prob cut a bit of a deal on both as well
Old 08-05-2010, 03:07 PM
0/11 sssss1869
im also curious y r dd box specs are so large for the smaller drivers..and how close are there numbers.to real world
Old 08-05-2010, 05:49 PM
0/11 sssss1869
pm me price on both best shipped thanks.
Old 08-05-2010, 05:52 PM
0/11 sssss1642
not sure, we had them in 2.8 cu ft...tuned to 35
Old 08-05-2010, 05:56 PM
0/11 sssss1642
pmd
Old 08-06-2010, 11:22 AM
0/11 sssss1642
sale pending, but ttt till than
