[SOLD] RE Audio RE 10" subs 100shipped NO TRADES - Car Audio Classifieds!
Old 02-22-2009, 07:40 PM
0/11 sssssss63
Default [SOLD] RE Audio RE 10" subs 100shipped NO TRADES
1. Product: Reaudio Re 10" subs SOLD
* 10"
* 175w RMS (600-800 watts peak)
* Dual 4 ohm voice coil
* Mounting Depth - 5"
* Mounting Hole Diameter - 9.125"
* Overall Diameter - 10.125"
* Bolt Hole Circle - 9.75"
* Motor Width - 4.875"
* Motor Depth - 1.5"
* Basket Depth - 3.5"
* Displacement - 0.09 cu. ft.
* Weight - 6.5 lbs.
* Mica Filled Poly Cone
* Santoprene Rubber Surround
* Pressed Steel Basket
* High Temp 8-layer Copper Voice Coil• FEA Optimized Motor Structure
* Single Magnet
* Linear Conex Spiders
* Foam Gasket
* Sealed Box Dimensions: .35 - .5 cubic feet
* Ported Box Dimensions: .65 @ 35 HZ - 1.0 @ 35 HZ
* Electrical Q Value -Qes: 0.39
* Mechanical Q Value -Qms: 4.37
* Total Speaker Q Value -Qts: 0.36
* Free Air Resonance -Fs: 21.5 Hz
* Equivalent Compliance -Vas: 75.6 liters
* One-Way, Linear Excursion -Xmax: 12 mm
* Efficiency -SPL 1W/1m: 84.7 dB SPL
* Effective Piston Area -Sd: 322 cm^2
NEW BNIB NEVER USED
4. Price: :100SHIPPED
5. Pictures: just the re subs are fs all others are possibly sold!!!!!
Last edited by jonesy; 04-14-2009 at 03:17 PM. Reason: Title needs to be more specific
Old 04-14-2009, 03:17 PM
0/11 sssssss63
sold lock it up
[SOLD] Crunch PowerZone P1100.2 $100shipped (negotiable) waresgaragestereo 2-Channel Amplifiers 2 01-12-2009 03:02 PM
[SOLD] DD audio/Digital designs 9515f $260 or trades need coaxes or comps!! jdubbau 15" Subwoofers 41 11-19-2008 11:54 PM
[SOLD] Kicker Subs and Planet Audio Amp ckyroboto Car Audio Packages 7 11-13-2008 10:20 PM
[SOLD] Exodus Audio DPL-10's IB subs 10" nismos14 10" Subwoofers 2 09-18-2008 08:57 PM
