3HP Sub woofers, eclipse and audio pulse
12'' ti frame
12'' audio pulse high roll surround
3'' dual 2 ohm 8 layer coil
3HP motors
two nicleyspaced spiders for coil control
removable top assemblies
if you know what your doing 2kwrms+
will provide tsp if requested or ill post when i have more time
TSP Specs
Re = 1.0938 ohms
Fs = 29.5954 Hz
Zmax = 21.4161 ohms
Qes = 0.4567
Qms = 8.4855
Qts = 0.4334
Le = 1.6040 mH (at 1 kHz)
Diam = 254.0000 mm ( 10.0000 in )
Sd = 50670.7504 mm^2( 78.5398 in^2)
Vas = 21.7413 L ( 0.7678 ft^3)
BL = 14.6991 N/A
Mms = 485.1612 g
Cms = 59.6081 uM/N
Kms = 16776.2344 N/M
Rms = 10.6319 R mechanical
Efficiency = 0.1159 %
Sensitivity= 82.6607 dB @1W/1m
Sensitivity= 91.3023 dB @2.83Vrms/1m
Krm = 25.829E-03 ohms Freq dependent resistance
Erm = 634.146E-03 Rem=Krm*(2*pi*f)^Erm
Kxm = 63.862E-03 Henries Freq dependent reactance
Exm = 553.656E-03 Xem=Kxm*(2*pi*f)^Exm
top Assembly is new never used or mounted, new frames fresh off the boat. motors are used from eclipse ti line
$375shipped each, i will be shipping in two boxes.
3 subs left
trades are welcomed
need some real nice speakers for my tube amps
big amps and if needed ill add cash
pm me with trade or any type of deals
12'' ti frame
3HP motors
TSP Specs
Re = 1.0938 ohms
Fs = 29.5954 Hz
Zmax = 21.4161 ohms
Qes = 0.4567
Qms = 8.4855
Qts = 0.4334
BL = 14.6991 N/A
Mms = 485.1612 g
Cms = 59.6081 uM/N
3 subs left
trades are welcomed
