Box request for JOSEPHKEMP - Car Audio Classifieds!
Old 05-15-2009, 11:45 PM
0/11 ssssss111
Cool Box request for JOSEPHKEMP
1. Car. Year, Make, Model:1986,oldsmobile,cutlass supream 2dr
2. Subs. Make, Model, Size, How many:re audio,12",4subs
3. Power. How much power per sub:1000watts
4. Goal. SPL or SQ:loud sq
5. Sealed or portedorted
6. Sub/port placement:i need the box to be 7.9 cubic ft with 90square inches of port opening with a port 25 inches long which is 3" wide x 30" long i think these are specs for my car from greg @ re audio tech support
7. Max dimensions:before the dip which is the (hump) 44"L X 10"H X 14"D. After the dip it's 54"L x 15.5" H x 20"D hope u can help
8. Desired NET vol and tuning(optional):36hz
9. Finish:black carpet
10. Zip code for shipping:32792
11) Additional commentsouble baffle/flush mount,Round over all port edges inside and out,Round over all outside edges,45's in all inside corners and what dose Kerfed port and walls do do i need this ca i get some more info on this and if i get u to build the box can u do it from the inside of the hump and bring it out towards the front of the trunk i want to port the box through the rear deck with a l shape port can u do the port to.
Double baffle:
Double baffle/flush mount:
Round over all outside edges:
45's in all inside corners:
Kerfed port:
Kerfed walls:
Slanted back:
Paint inside of port:
Old 05-16-2009, 09:52 AM
Ami Creations's Avatar
Loyal Member
0/11 sssss1064
You got PM
[CLOSED AT OP REQUEST]wtb amp soon extremechevyman67 Wanting to Buy (WTB) 6 03-31-2009 06:29 AM
Box request for probmxstyle probmxstyle Box Requests 2 03-25-2009 08:04 PM
Box request for tater tater Box Requests 1 03-18-2009 11:09 PM
Box request for tapout383 tapout383 Box Requests 2 03-16-2009 10:34 AM
Request BLACKonBLACK98 CarAudioClassifieds' Power Seller Program 4 11-01-2008 11:31 AM
