2 RD ALPHA v2 15's in Jimmy - Car Audio Classifieds!
Old 05-18-2009, 08:26 PM
jdubbau's Avatar
0/11 ssssss268
Default 2 RD ALPHA v2 15's in Jimmy
I am using 1 1/8 inch mdf for the build and would like to do either slot port or 6 inch pvc with rounded off outside and inside wood for flairs (prefered)
$15 for design and cutsheet if someone can do it tonight? 5-18-09
1. Car. Year, Make, Model:2000 GMC JIMMY (BLAZER LAZER)
2 15" upgraded ALPHA V2
2000-2500wrms
4. Goal. SPL or SQ:BOTH but leaning more to spl for comps with good sound for daily driving
5. Sealed or ported:Ported
6. Sub/port placement:Up to designer for best output subs up port back is what most say but I have seen a few with sub up port up, subs to side port back?
7. Max dimensions:
17" tall x39" wide x28" deep is probably how I am gonna have to do it to get the box big enough with ports firing back. I could go to 17.5 if I could recess the subs into the box.
7-8 after displacements as subs have a .23 displacement I beleive? And I am using 1 1/8 inch thick MDF
9. Finish: MDF Painted with fleckstone paint or rhino liner
10. Zip code for shipping:NO SHIPPING JUST DESIGN AND CUTSHEET
11) Additional comments:Would like to tune around 42hz or so as suv resonant frequenc is around 50hz or so. Also up to designer on best results as tuning to 40hz worked well and sounded ok so I may be able to go up to 45hz or so and still have ok sq?
Double baffle:Maybe depending on room
Double baffle/flush mount:Maybe depending on room
Round over all port edges inside and out:Yes
Round over all outside edges:Yes
45's in all inside corners:ALWAYS
Kerfed port:Not this time
Kerfed walls:Back front wall maybe by rear seats
Slanted back:Nope
Paint inside of port:Yep
REFS//// BOUGHT FROM
Wenn_du_weinst, SMiller, Basic1906, BRYANCAIN(TWO FI 18" Q'S), SOLD TO SPY (TC3000/LA STORM 12'S)
J-DUBB-A-U
2000 JIMMY
PRS800
LOOKING 2 BUY
LOOKING 2 BUY
1 US Amps TU600c (Hybrid Tube)
1 Diamond Audio HEX Comps
Old 05-19-2009, 10:19 AM
Ami Creations's Avatar
Loyal Member
0/11 sssss1064
Hey call me so I can talk to you about this box. I have the design already made. Just need to ask you a few questions.
(404)-510-6598
Old 05-19-2009, 10:20 AM
Loyal Member
0/11 sssss1064
Hey, call me so I can talk to you about this box. I have the design already made. Just need to ask you a few questions.
(404)-510-6598
WTB 1 or 2 15's alex95sl2 Wanting to Buy (WTB) 3 02-03-2009 09:02 PM
wtt 2-12 rd alpha scott s Car Audio Trader (WTT) 19 01-09-2009 07:37 PM
RE MT 15's ibanender 15" Subwoofers 8 12-03-2008 01:38 PM
Re sx 15's DLP customs 15" Subwoofers 31 11-02-2008 12:10 PM
