Box DESIGN request for ChromeJerome - Car Audio Classifieds!
Old 11-26-2012, 11:27 PM
0/11 ssssssss8
Default Box DESIGN request for ChromeJerome
1. Car. Year, Make, Model:
1999 Chevy Blazer 4 Door
(2) Skar VVX-12 Dual 4 ohm
They are rated at 600 rms each, but I will be feeding them around 1000 rms each off of a Crescendo [email protected] 1 ohm
4. Goal. SPL or SQ:
SPL with ability to still hit teh lows
5. Sealed or ported:
Ported
6. Sub/port placement:
Preferred subs on top, port on back, but open to suggestions.
7. Max dimensions:
Base of seat to hatch/tailgate: 36"
Top of seat to hatch/tailgate 33" (These two, I'm sure you already know, but this will be right up against the tailgate/back wall, as in less than an inch or inch and half of room between the box and back. Port needs to have room to breathe)
Height to top of seat: 16", But the box can be 20" tall at most.
Wheel well to wheel well: 37.5"
**The only key things are that I will have an amp rack that is 11" deep, the direction from the backseat to the tailgate. So the two depths are really 22" and 25". **
Skar calls for about 2 cu ft. per sub, so in the 4-5 neighborhood. Also wanting what is best for my goal as previously stated, high 20's to mid 30's, whatever would work best.
9. Finish: I would be having someone else build and upholster it, but if it helps with design any, the enclosure will be carpeted, and my amp rack will be painted or powdercoated.
11) Additional comments:
Double baffle:
Double baffle/flush mount:Yes
Round over all outside edges:
45's in all inside corners:
Kerfed port:
Kerfed walls:
Slanted back:
Paint inside of port:
Old 12-05-2012, 12:01 PM
0/11 sssss1898
Do you still need this.
2002 suburban
Security System
Code alarm
Electrical
Dc power sp270 7 deka 9A31's and lots of 1/0
Headunit
pioneer 880prs
Amps
Sax125.2 front stage 2 Saz-4500's [email protected] 1 ohm
Wiring
lots of 1/0 stinger, tsunami
Mids & Tweeters
Dd w6.5 mids and lanzar opti crossovers and tweets
Subs
4-18" nightshade v2's d2
System Details
Daily driver.
Old 12-05-2012, 11:01 PM
0/11 ssssssss8
No man thanks though!
box design request djscrubb General Car Audio Discussion & Questions 1 12-04-2011 06:03 PM
Box design request mythyone Off Topic Chat 1 05-12-2010 01:49 PM
Box design request for brtnboarder3241 brtnboarder3241 Box Requests 11 06-21-2009 04:25 PM
