Box request for BASS14 - Car Audio Classifieds!
Old 02-28-2013, 03:36 PM
BASS14's Avatar
0/11 sssss1086
Default Box request for BASS14
1. Car. Year, Make, Model: 1999 ford Ranger
2. Subs. Make, Model, Size, How many: 2 SSA XCON 15s
3. Power. How much power per sub: Cactus Sounds K5 at half ohm so 2200-2700 per sub id imagine
4. Goal. SPL or SQ: ground pounder that does respectable numbers
5. Sealed or ported: Ported...Blow Through
6. Sub/port placement: cent port sub on each side of port facing forward (blow through)
7. Max dimensions:39"wide 15" tall and up to 65" deep use the width and hieght i gave adjust the depth to get desired specs
8. Desired NET vol and tuning(optional): looking for the 7.5-8cubic foot range after dis tuned in the low to mid 30s
9. Finish:
10. Zip code for shipping:
11) Additional comments: no shipping just looking for a design and cut sheet i can do the build.
Double baffle:y
Double baffle/flush mount:no
Round over all port edges inside and out:no
Round over all outside edges:no
45's in all inside corners:yes
Kerfed port:no
Kerfed walls:no
Slanted back:yes will need to be angled back to fit 15s on the baffle
Paint inside of port:
Subs-2 15" SSA XCONs
box-Huge 4th Order BlowThrough
Deck-Kenwood KDC-X996
Amp-Cactus Sounds K5 wired at half ohm
Wireing-knukonceptz through out
Battery(s)-2 NGT Extreme NG31s project db terminals
Old 02-28-2013, 03:38 PM
bumpin buick's Avatar
Loud Noises
0/11 sssss9731
Feedback Score: 31 reviews
pair of 15s?
Your max height is 15" but the baskets measure 15.5?
Old 02-28-2013, 03:41 PM
BASS14's Avatar
0/11 sssss1086
Originally Posted by bumpin buick View Post
pair of 15s?
i might be able to do 16" but would rather do 15" tall and just have the baffle angled back to fit the 15s...
Old 02-28-2013, 05:00 PM
BASS14's Avatar
0/11 sssss1086
well i just went and measured again, i can do 16" tall but not any taller....
Box build for BASS14 Ami Creations General Car Audio Discussion & Questions 32 12-30-2010 06:56 PM
Att: Bass14 RustyWCA (DC) 30 02-16-2009 09:49 PM
Bass14.... Patrick Simmons Off Topic Chat 15 11-02-2008 10:14 PM
