Bandpass 4th order or slot ported help - Car Audio Classifieds!
Old 07-31-2009, 09:05 PM
0/11 ssssss138
Default Bandpass 4th order or slot ported help
1. Car. Year, Make, Model:
2001 F-150 blowthrough
4 15's AA chaos.
1krms per sub so total 4krms
4. Goal. SPL or SQ:
SPL, daily loud so not really spl dont care bout the meter just want a nice box that hits low moves air and flex, like a 32-33hz tuned ported box plays.
5. Sealed or ported:
4th order bandpass and slot ported would like to see two designs
6. Sub/port placement:
bed in blowthrough
7. Max dimensions:
48x20x57. would like to keep it at 55 if possible if not that extra 2" is no big deal if needed for proper airspace
dimensions are external as well
either two layers of 3/4 mdf or one layer of 1" mdf with lots of bracing?
w/e works best for daily pounding system for the slot ported in the 32-33hz area for 4th order bandpass unsure dont know bout those?
9. Finish:
10. Zip code for shipping:
11) Additional comments:
Just need a few different designs to see what i think will perform the best for daily.
Thanks Will pay you for your time if i pick your box. just want a few diff ones to see the best route.
Double baffle:
Double baffle/flush mount:
Round over all outside edges:
45's in all inside corners:
Kerfed port:
Kerfed walls:
Slanted back:
Paint inside of port:
Anyone Ever Seen A Slot Ported..... only126db General Home Audio/Video 6 12-08-2009 04:23 PM
12" subwoofer - 4th order vs ported grimreper912003 General Car Audio Discussion & Questions 8 06-20-2009 11:08 AM
Slot port and BBP craiggus365 General Car Audio Discussion & Questions 20 05-22-2009 01:40 PM
New box in the Legacy Wagon - 2 12" RE SX 4th order bandpass hollatchaboy Build Logs 6 05-19-2009 11:36 PM
[BASIC] Sealed vs Ported vs Bandpass (4th order) danteBirosel Tutorials & Quick References 0 11-12-2008 01:47 PM
