Box request for JPence23 (2012 Crew Cab Silverado) - Car Audio Classifieds!
Old 05-06-2013, 10:58 PM
30hz&below
0/11 ssssss287
Default Box request for JPence23 (2012 Crew Cab Silverado)
1. Car. Year, Make, Model: 2012 Crew Cab Silverado
2. Subs. Make, Model, Size, How many: 1 Sundown, SD2-10, 10"
3. Power. How much power per sub: 500w rms
4. Goal. SPL or SQ: SPL/SQ
5. Sealed or ported: Ported
6. Sub/port placement: most likely upfire with port to passenger side??
7. Max dimensions:
8. Desired NET vol and tuning(optional): 1cu ft @35-38hz
9. Finish:
10. Zip code for shipping: i will build
11) Additional comments:
Double baffle:
Double baffle/flush mount:
Round over all outside edges:
45's in all inside corners:
Kerfed port:
Kerfed walls:
Slanted back:
Paint inside of port:
Hoping to find some one that has a under seat ported box design for this truck that will fit this beastly sub. Was thinking an aero port design but cant figure up a design myself due to the bars under the seat.
thanks in advance, Justin
email - [email protected]
2012 Silverado Crew Cab Box Ikyo75 Enclosure Discussion & Design Construction Help 10 04-01-2013 01:29 PM
Fiberglass Ported Box for 4 8" Subs for 07+ Crew Cab Silverado/Sierra & 3" Seat Lift Texas Edition Wiring, Electrical & Other Installation Equipment 3 03-29-2013 05:35 PM
X-post regarding unique crew cab box idea? rideit Enclosure Discussion & Design Construction Help 31 03-12-2011 11:04 PM
Crew Cab Box Pic Request. 350zkid General Car Audio Discussion & Questions 5 03-12-2010 03:56 PM
Non-Wall Sub / Port Direction In Silverado Crew Cab duramaxxed General Car Audio Discussion & Questions 10 02-25-2010 11:46 AM
