Box request for Kcbme - Car Audio Classifieds!
Old 06-04-2013, 06:31 PM
Kcbme's Avatar
0/11 ssssss526
Default Box request for Kcbme
1. Car. Year, Make, Model:2002, Ford, Explorer sport trac
2. Subs. Make, Model, Size, How many:Obsidian Audio, D2, 12,4
3. Power. How much power per sub:Ab 150.1 2900 rms @ 1ohm, 725 each
4. Goal. SPL or SQ:
I want to be able to murder the lows with authority
5. Sealed or portedorted
6. Sub/port placement:Not sure What ever works best in my situation
7. Max dimensions:48 wide, 24,depth, and 24 height(can go higher if needed but wanted to try and keep about even with windows
says 2 feet cube each so 8 feet cubed?With 30 Hz tuning
9. Finishark grey OEM carpet or some kind of black finish I'm open to options
10. Zip code for shipping:design
11) Additional comments:I have removed all the rear seats in the back and built a platform to level it out.
Double baffle:yes
Double baffle/flush mount:
Round over all port edges inside and out: Does it help much?
Round over all outside edges:
45's in all inside corners:Yes
Kerfed port:
Kerfed walls:
Slanted back:
Paint inside of port:
Box request for L a r r y L a r r y Box Requests 1 07-19-2012 08:01 AM
Box request for AR-15 AR-15 Box Requests 5 05-03-2011 08:24 AM
Box Request PhishHead Off Topic Chat 0 11-20-2010 06:44 PM
Box request chevytoy Off Topic Chat 1 11-20-2010 03:21 PM
