Box request for statonburrell - Car Audio Classifieds!
Old 08-12-2009, 02:35 AM
statonburrell's Avatar
go big or go home
0/11 sssss1896
Default Box request for statonburrell
1. Car. Year, Make, Model:
2007 toyota tacoma double cab
4 sundown e8's
250W
4. Goal. SPL or SQ:
5. Sealed or ported:
ported
6. Sub/port placement:
subs will need to be placed on the slanted side of the box. Port will probably need to be on the sides, might have to be aero ports.
7. Max dimensions:49"L X 18.25" H X 8" bottom depth X 4" top depth. the back side of the box will be flat. also, there is a bracket on the driver side of the truck. the seat bracket on the bottom part is 17.5" over and goes to 20" over and is 4.5" tall so a slot will need to be cut into the bottom of the box here like an n shape. and there is a cab bracewhere the back of the box would sit. back brace is at 10" up and goes to 13.5" it sticks out 2.25". so the box would need to be c channeled here.
2 cuft @ 30hz
9. Finish:
black
10. Zip code for shipping:
29072
11) Additional comments:
would really like this ASAP, can paypal funds whenever needed.
Double baffle:
Double baffle/flush mount: flush mount
Round over all port edges inside and out: yes
Round over all outside edges: yes
45's in all inside corners:
Kerfed port:
Kerfed walls:
Slanted back:
Paint inside of port: yes
there are also similar boxes on ebay for these trucks so you can get a look at them there to see what I am talking about with the notches and stuff.
Old 08-26-2009, 05:24 AM
iamamp3pimp's Avatar
0/11 ssssss661
the space you gave is 2.07 cubic feet before any displacement and before the N section was removed.
Robin Butler
Getting back into the swing of Bass Race after a small hiatus
Old 08-26-2009, 08:53 PM
go big or go home
0/11 sssss1896
be close enough though right?
Box request #2 for 92K1500 92K1500 Box Requests 39 05-08-2009 03:17 AM
[CLOSED AT OP REQUEST]wtb amp soon extremechevyman67 Wanting to Buy (WTB) 6 03-31-2009 06:29 AM
Box request for jdubbau jdubbau Box Requests 2 03-29-2009 12:17 PM
Request BLACKonBLACK98 CarAudioClassifieds' Power Seller Program 4 11-01-2008 11:31 AM
