Box request for oxsign - Car Audio Classifieds!
Old 06-23-2014, 08:04 PM
oxsign's Avatar
0/11 sssss1876
Default Box request for oxsign
1. Car. Year, Make, Model:
2010 Avalanche
4 15" CT Strato
800-1K CT3K
4. Goal. SPL or SQ:
SQL
5. Sealed or ported:
Ported
6. Sub/port placement:
Center, but open to opinions.
7. Max dimensions:
49" W x 21" H x 48" D
Open
9. Finish:
Raw
10. Zip code for shipping:
Just need a design. I'd like to build.
11) Additional comments:
Double baffle: yes
Double baffle/flush mount: yes
Round over all port edges inside and out:yes
Round over all outside edges: yes
45's in all inside corners: yes
Kerfed port:
Kerfed walls:
Slanted back:
Paint inside of port:
1971 VW Fastback
Old 06-23-2014, 08:06 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
ygpm bro
SHABAM
Old 07-11-2014, 02:44 PM
oxsign's Avatar
0/11 sssss1876
Back up. I need a design from someone please. Thx.
1971 VW Fastback
Old 07-14-2014, 06:59 PM
oxsign's Avatar
0/11 sssss1876
Up..........
1971 VW Fastback
Old 07-15-2014, 09:48 AM
oxsign's Avatar
0/11 sssss1876
Up......
1971 VW Fastback
Old 07-23-2014, 02:35 PM
0/11 ssssss172
Are you looking for a blowthrough type design, firing in through the removeable area behind the rear seats? For SQL you could fit a 1:1 ratio series tuned 6th order. If interested I can design you up something. This is an example of my work.
Old 07-23-2014, 04:16 PM
oxsign's Avatar
0/11 sssss1876
Yes sir, a blow thru type of design. I'm not picky about standard ported, 4th, or sixth. I can built it, I just need a design. Please let me know if you could. I'm very interested.
1971 VW Fastback
Old 07-23-2014, 04:38 PM
0/11 ssssss172
I'll work up a design and let you see what you think. Going by the Qts of the subs, they will be better suited in a ported or 6th order application. Since you have the space and are wanting more of a SQL set up, a series tuned 6th will be ideal. It'll be very efficient while having closer to a 1:1 ratio will keep it very daily and musical. What's an email I can reach you at? I'll send you an image of the design by this evening.
Old 07-23-2014, 06:34 PM
oxsign's Avatar
0/11 sssss1876
You are the man!!!! you can send it to [email protected] please. Thank you.
1971 VW Fastback
Box request for oxsign oxsign Box Requests 1 01-16-2010 07:02 PM
