Box request for kdhs10 - Car Audio Classifieds!
Old 01-19-2015, 02:25 PM
0/11 sssssss13
Default Box request for kdhs10
1. Car. Year, Make, Model:1997 Chevrolet Tahoe 2 Door.
2. Subs. Make, Model, Size, How many:CT Sounds Meso 15, 2 of them.
3. Power. How much power per sub:Crescendo BC3500, so around 1950 per sub.
4. Goal. SPL or SQ:A little of both I guess, it's not a daily vehicle but I do drive it every couple days.
5. Sealed or ported:Ported
6. Sub/port placement:Both up probably, it's in a SUV but there won't be much room between the box and rear doors.
7. Max dimensions: Depth-17" Width-46" Height-as low as feasible.
8. Desired NET vol and tuning(optional):Whatever works best.
9. Finish:
10. Zip code for shipping:
11) Additional comments:I plan to build a false floor over the subs in order to carry gear to car shows and what not. Also would like to end up with something similar to this pic.
Double baffle:Yes
Double baffle/flush mount:Yes
Round over all port edges inside and out:I probably will
Round over all outside edges:I probably will
45's in all inside corners:Most likely
Kerfed port:
Kerfed walls:
Slanted back:
Paint inside of port:
Box request for 1-12-t1 1-12-t1 Box Requests 0 07-02-2012 06:53 PM
Box request for 1-12-t1 1-12-t1 Box Requests 0 05-14-2012 06:48 PM
Box request help jwright0291 General Car Audio Discussion & Questions 3 11-29-2011 09:41 PM
Box request for ED E3.6 $$$$ Pieper Box Requests 0 05-04-2010 04:35 AM
