Box request for grndfx - Car Audio Classifieds!
Old 03-05-2015, 03:33 PM
0/11 sssssss93
Default Box request for grndfx
1. Car.: 1994 gmc suburban no third row 65" long, 25" wide of free space to use if I need it all
2. Subs. Sundown Audio zv2 18's Dual voice coil 2 ohms
3. Power. running a bc3500 @ 1/2 ohm so I guess 1500 watts per speaker?
4. Goal. SPL
5. Sealed or ported: ported
6. Sub/port placement: Subs facing up towards roof, port facing out towards back doors.
7. Max dimensions: 65" long 25" wide 20" tall
8. Desired NET vol and tuning(optional):?? I dont know I am new
9. Finish: carpet
10. Zip code for shipping: 17404
11) Additional comments:
Double baffle:
Double baffle/flush mount:
Round over all outside edges:
45's in all inside corners:
Kerfed port:
Kerfed walls:
Slanted back:
Paint inside of port:
Old 03-05-2015, 05:58 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
If you use the full available space you could do about 13.5 net at 35hz tuning with 4 8" aeros 20" long. At nearly 15" of port per cube it should meter very well and play well into the upper 50's and should still dig pretty well into the high 20's
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
The Following User Says Thank You to e46inperrycounty For This Useful Post:
grndfx (03-05-2015)
Old 03-05-2015, 06:00 PM
0/11 sssssss93
that would be fine. Would anyone be able to draw me up a box using google sketch up or something so i know the cutting dimensions ect.
Old 03-05-2015, 06:05 PM
0/11 sssss8594
Feedback Score: 55 reviews
13cu is huge for those subs...specs call for 4cu each
Enclosures
Old 03-05-2015, 06:06 PM
0/11 sssss8594
do u need a box built or just designed??...i live in fort washington so im probably less than an hr from u and i build boxes if u needed it
Enclosures
Old 03-05-2015, 06:08 PM
0/11 sssssss93
I was gonna do it myself, but i don't really understand the logistics behind figuring out what is the best box for certain subs. I was wonding if someone with some free time could sketch up a plan for me with all the dimensions and such and I would do the building
Old 03-05-2015, 06:11 PM
So Low's Avatar
0/11 sssss1258
I agree, zv2 is a small box woofer, relatively speaking. But that's not a bag thing, more volume for port. I'd do a single slot port, on the big side. I'll have some time tonight to whip up a design if you need it sooner than later
The Following User Says Thank You to So Low For This Useful Post:
grndfx (03-05-2015)
SPL Farms
0/11 sssss5706
4 cubes for an 18??
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 03-05-2015, 06:13 PM
0/11 sssssss93
I would be very greatfull if you could. Thanks
Old 03-05-2015, 06:16 PM
So Low's Avatar
0/11 sssss1258
Originally Posted by e46inperrycounty View Post
4 cubes for an 18??
Yep. Vas is below 140 liters for the zv2, the x series 18 as a comparison has a vas well above 200 liters
Stiff cones on them sumbishes
Box request for L a r r y L a r r y Box Requests 1 07-19-2012 08:01 AM
DC Xl box request cjbellmore Off Topic Chat 0 01-10-2011 06:42 PM
Box request chevytoy Off Topic Chat 1 11-20-2010 03:21 PM
Box request for ED E3.6 $$$$ Pieper Box Requests 0 05-04-2010 04:35 AM
