Box request for Austin175 - Car Audio Classifieds!
Old 03-12-2015, 01:44 PM
Austin175's Avatar
0/11 sssss4224
Default Box request for Austin175
1. Car. Year, Make, Model: 1997 Jeep Grand Cherokee
2. Subs. Make, Model, Size, How many: Tantric Hdd 18s(pair)
3. Power. How much power per sub: well ill be running an B2 M1S so 2500+
4. Goal. SPL or SQ: in the middle more for daily then numbers
5. Sealed or ported ported
6. Sub/port placement: either subs on bottom port across the top or subs an port in the middle
7. Max dimensions: 40" W, 38"H, 30"L
8. Desired NET vol and tuning(optional): 13'14cubes an 32-35Hrtz for tuning
9. Finish: bare ill paint myself
10. Zip code for shipping: no need for shipping just need design an cut sheet
11) Additional comments: the wall will be doubled layered all around using 3/4 MDF an alot of bracing use 3/4 all thread an want to flush mount the woofers
Double baffle:
Double baffle/flush mount:
Round over all outside edges:
45's in all inside corners:
Kerfed port:
Kerfed walls:
Slanted back:
Paint inside of port:
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
Request for Austin175 Austin175 (Fix My Speaker) 4 04-30-2012 08:21 PM
Price Quote for Austin175 Austin175 Alternator Price Quote Section 1 04-07-2012 06:53 PM
