Box design request for Shooter - Car Audio Classifieds!
Old 10-27-2009, 02:51 PM
Shooter's Avatar
0/11 sssssss61
Default Box design request for Shooter
1. Car. 1940 Dodge coupe
2. Subs. (One) Ed 160v2 15" sub
3. Power. 350x1 @ 2ohm
4. Goal. SQ for videos
5. Sealed or ported:Ported please
I am finally to the point in my project where I need to make and install my sub box, so I will be able to finish off the trunk area of the car.
I am including the shape of the box, which is necessary for the size of my car. The speaker info, and the amp info.
I am hoping to get the most out of this speaker and amp, and that's why I need your help. I have no idea how to determine the length of the port, or where to put it in a box this shape. I figure I will use 3/4 mdf for the box, and I figured I would just put the sub facing forward ( on the angle part of the box) as I will have an oval hole through the rear seats center console.
I chose this amp setup to be able to take advantage of it looking just like the front stage amp that has surround sound. I know the amp is small, and the speakers rms is big, but I ordered the speaker, just to find out that the model was dicontinued, so they just upgraded me to this 160v2 at n/c.
Long story... sorry. I NEED HELP PLEASE.
Here are the specs on the box shape I need, the height and width are not as critical as the side view ;
SPEAKER ED 160v.2
Qts: .36
Qes: .42
Qms: 3.0
Fs: 23.00Hz
Re: 7.0
Vas: 254L
Mms: 202.0g
Bl: 22.10T*m
Spl: 91dB
Sd: 872cm2
Xmax: 21.0mm
Voice coil: 62.5mm
Magnet width: 7.200”
Cutout diameter: 13.750”
Mounting depth: 8.125”
Weight: 42lb
Total height: 8.750”
Displacement: .08 ft3
Outside diameter: 15.375”
Box size suggestions from ED
Vented (ideal) 2.2 ft3 Tuned to 30Hz
Vented (DDLoud) 2.5 ft3 Tuned to 35Hz
AMP Alpine MRP-M350
Rms power : 200x1
Power at 2 ohm: 350x1
Class D amp
More info on the equipment is here:
http://www.crutchfield.com/p_500MRPM...ures_and_specs
http://www.edesignaudio.com/product_...products_id=36
Thank you for your time
Old 10-27-2009, 02:59 PM
Shooter's Avatar
0/11 sssssss61
OK now that I can see that the pic didn't turn out like I figured it would I am going to try and tell the LxWxH of the box.
the front view is a square 21" in length x 23 in heigth.
The side view is from bottom left to bottom right. 10" with a cut out of 4.5". The heigth of the rear of the box is: 8" cut out, then 15" equalling 23". The top of the box is from rear to front, 10.75". The angle of the front of the box is at a 20 degree angle.
Sorry about the pic not working, I have been trying all day to get it on here, and this is what I get.
Old 10-27-2009, 03:41 PM
Shooter's Avatar
0/11 sssssss61
Sorry for not being clear as to what I need, so here goes:
Could I get help on tuning this size box, and help on port size, and placement of port?
Old 10-27-2009, 07:51 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
go with aeros awesome means of porting an enclosure!
SHABAM
Old 10-28-2009, 08:34 AM
Shooter's Avatar
0/11 sssssss61
AEROS?
Old 10-28-2009, 08:48 AM
Bender-Offender's Avatar
0/11 ssssss142
Originally Posted by Shooter View Post
AEROS?
http://www.psp-inc.com/
Old 10-28-2009, 11:43 AM
Shooter's Avatar
0/11 sssssss61
Alright thanks. Now how would I go about figuring the cubic feet of the box with the speaker in? Is there a program I need to find, or would I be able to get help here?
Old 10-28-2009, 03:39 PM
Shooter's Avatar
0/11 sssssss61
Found that at 12volt.com. I figured I'd try myself, and I said screw it. I can't figure out how to put a port in, and also figure out the correct cf.
I suppose I will try a sealed box instead. Anyone help me please
Old 10-29-2009, 03:35 AM
DonH's Avatar
0/11 sssss6645
pm me ill design for $10 paypal. check out my section of carstereoforum.net under D.H. Designs. read the MUST READ
SHABAM
Box Design Request for 350zkid 350zkid Box Requests 3 11-13-2009 02:42 AM
Design request for BlackWaterOp BlackWaterOp Box Requests 1 10-17-2009 12:40 PM
Design request for Tom Gralewski Tom Gralewski Box Requests 5 10-04-2009 10:57 AM
Box Design request for Biggy Biggy Box Requests 0 07-04-2009 11:20 AM
DESIGN request for nitro_freak1 nitro_freak1 Box Requests 13 12-07-2008 08:35 PM
