Box request for jones82joshua - Car Audio Classifieds!
Old 04-16-2016, 12:53 AM
Stress tester
0/11 sssssss63
Default Box request for jones82joshua
1. Car. Year, Make, Model: 2004 Cadillac SRX
2. Subs. Make, Model, Size, How many: 2x SSA XCon 15"
3. Power. How much power per sub: 1500-2250 rms
4. Goal. SPL or SQ: Can't we have it all? 60/40 sq/spl
5. Sealed or ported: ABC
6. Sub/port placement: Up/Up
7. Max dimensions: 39wx35lx18h
8. Desired NET vol and tuning(optional): 7-8 cubes, no higher than 32hz on larger chamber
9. Finish: n/a
10. Zip code for shipping: n/a
11) Additional comments: Sub/Port facing up; ports on either end or either side--whichever works. Prefer to go the full 39x35 width/length, height not critical. Plans only.
Double baffle: Yes
Double baffle/flush mount: Yes
Round over all port edges inside and out: No
Round over all outside edges: No
45's in all inside corners: No
Kerfed port: No
Kerfed walls: No
Slanted back: No
Paint inside of port: n/a
Old 04-16-2016, 09:11 AM
So Low's Avatar
0/11 sssss1258
Easy enough.
Side view:
7 cubes tuned to 29. You leaned more towards the SQ side so the slightly lower tuning will met a lower group delay, but feel free to go nuts with the bracing and/or 45s to soak up some volume. Shorten the port by four inches if you want to tune a bit over 30. 45 in the port corner if you believe in doing that, but definitely round over the wood making up the port walls. Only the baffle is doubled up so you should brace where you can.
Enjoy
Old 04-16-2016, 09:47 AM
Stress tester
0/11 sssssss63
Sorry, this was meant to be Aperiodic Bi-Chamber, not a standard vented. I do appreciate the quick reply and the effort though, thank you.
Here's an example of the type of enclosure I'm looking for..
Old 04-16-2016, 09:53 AM
So Low's Avatar
0/11 sssss1258
I gotcha. Might I ask why you want to go aperiodic? The xcons aren't very peaky, which would be my choice for aperiodic chambering to tone it down.
Old 04-16-2016, 11:12 AM
So Low's Avatar
0/11 sssss1258
First off don't build this! Waste of wood, it'll be easier to use aeroports.
Only thing I really accomplished here was the volume ratio, 1.86 to 1 between chambers. Lower tuning is 28.5 the higher is 38. Are you just going for sheer output or trying to cancel out a resonance?
Old 04-16-2016, 06:23 PM
Stress tester
0/11 sssssss63
I had started by thinking about 6th order for a bump in output across a wider hump, but was worried about how much SQ I would sacrifice. Looking to keep as much SQ as I can with as much output as possible. I was under the impression that a properly designed ABC is the best compromise if you have the room. Not sure if that's true or not, but I wanted to try something new anyways.
Old 04-19-2016, 03:50 PM
bassfreak's Avatar
0/11 ssssss597
i'm familiar with that type of alignment. where ya get that? its been year since ive seen someone mention it..
Trade agreement between myself(Jones82Joshua) and Black Toyoda jones82joshua Trade Agreement Forum 8 12-06-2013 04:19 PM
Box request for jones82joshua jones82joshua Box Requests 0 08-08-2013 11:52 AM
Box request for 1-12-t1 1-12-t1 Box Requests 0 07-02-2012 06:53 PM
DC Xl box request cjbellmore Off Topic Chat 0 01-10-2011 06:42 PM
