Box request for Crownvicon24s - Car Audio Classifieds!
Old 12-19-2009, 09:19 AM
crownvicon26's's Avatar
0/11 sssss1882
Default Box request for Crownvicon24s
1. Car. Year, Make, Model: 1994 Ford Crown Victoria
2. Subs. Make, Model, Size, How many: RE SE 12'' X4
3. Power. How much power per sub: 750 to 800 rms
4. Goal. SPL or SQ: SQL
5. Sealed or ported: 4th order bandpass
6. Sub/port placement: Ported through the rear deck
7. Max dimensions: 21''LX40''WX25''H
8. Desired NET vol and tuning(optional): Don't know much about designing a 4th order, but whatever will give me a flat response
9. Finish: Grey Carpet
10. Zip code for shipping:29301
11) Additional comments: I really need to know if I have enough airspace to fit a box like this in my trunk. If it needs to be built inside of my trunk I would only need a box design. I will find someone local to build it. If builder is close to my location I will also be willing to drop the car off. In order for this box to clear the lip of my trunk the top back corner of the box was cut at a 45 degree angle that is about 4'' wide. I was told that my box might be blocking the airflow into the cabin of my car so I was thinking this design might fix this problem. Here are some pics:
[IMG]file:///C:/DOCUME%7E1/OWNER%7E1.YOU/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/OWNER%7E1.YOU/LOCALS%7E1/Temp/moz-screenshot-1.jpg[/IMG]
Double baffle: Yes
Double baffle/flush mount: No
Round over all port edges inside and out: No
Round over all outside edges: No
45's in all inside corners: No
Kerfed port: No
Kerfed walls: No
Slanted back: No
Paint inside of port: Black
Taramps 8k
2 Zv.3 15's
2.87:1 4th Order @ 48hz
Old 12-19-2009, 10:20 AM
0/11 sssss1882
ttt
Taramps 8k
2 Zv.3 15's
Old 12-19-2009, 11:47 AM
0/11 sssss1882
ttt
Taramps 8k
2 Zv.3 15's
Old 12-19-2009, 12:33 PM
0/11 sssss1882
If I dont have room for a 4th order I will also do a smaller ported box. I just need a design.
Taramps 8k
2 Zv.3 15's
Old 12-21-2009, 09:50 AM
0/11 ssssss125
what are you trying to achieve with the new box?? I am in north ga so we may be able to work something out...
Old 12-25-2009, 07:40 PM
0/11 sssssss23
pm sent
Old 12-25-2009, 07:46 PM
0/11 sssss1882
I thought the problem was my box size, but my box is fine I need to get another alt. Thanks for the help though guys.
Taramps 8k
2 Zv.3 15's
Box request for Crownvicon24s crownvicon26's Box Requests 2 12-19-2009 09:35 AM
Vid Request. 350zkid General Car Audio Discussion & Questions 12 11-23-2009 01:10 PM
Pic Request. 350zkid General Car Audio Discussion & Questions 17 09-21-2009 05:40 PM
Box request for blackice98 blackice98 Box Requests 0 05-26-2009 07:18 PM
Request BLACKonBLACK98 CarAudioClassifieds' Power Seller Program 4 11-01-2008 11:31 AM
