Box request - Page 2 - Car Audio Classifieds!
  #11
Old 04-20-2020, 04:36 PM
0/11 ssss31258
Originally Posted by fresh909 View Post
Can I get your PayPal so I can send funds
Sent from my SM-A505U1 using Tapatalk
[email protected]
Here is the easy link to send payment
PayPal.Me
Please remember to send it "trusted" as friends and family
Old 04-20-2020, 04:51 PM
fresh909's Avatar
1/11 sssssss59
Originally Posted by iamsonic View Post
[email protected]
PayPal.Me
Just sent u payment through paypal
The Following User Says Thank You to fresh909 For This Useful Post:
iamsonic (04-20-2020)
  #13
Old 04-20-2020, 04:53 PM
fresh909's Avatar
1/11 sssssss59
[email protected]
PayPal.Me
Funds sent
iamsonic (05-31-2020)
  #14
Old 04-20-2020, 04:57 PM
0/11 ssss31258
Cool
thanks!
Box designs for $35.
My 'business' name is BBS (it means Built By Sonic)
I'm in Waterloo Iowa.
I do box designs for $35 paid before hand.
Most designs are done within 2 days.
V this picture is a link... click it V
  #15
Old 04-20-2020, 05:00 PM
fresh909's Avatar
1/11 sssssss59
Cool
thanks!
  #16
Old 04-24-2020, 02:45 PM
0/11 ssss31258
Emailed to your PayPal email also.
Thank you!
I know you asked for a 4th order but a series tuned 6th order will be louder and sound better so I designed a series tuned 6th order for you.
The port sizes are optimized to be as small as possible without having port noise
When I design boxes, I intend on the builder using 3/4" material pre-drilled using a 7/64" drill bit on 6" or closer centers & screwed with common 1 5/8" coarse drywall screws.
If you want it stronger, use more screws between the 6" on center screws
Use glue in every joint.{except on removable panels}
For removable panels, I suggest using 3/4" wide open-cell foam tape Or felt tape Or carpet to seal where it meets instead of glue so it is easily removable.
I suggest making the top panel removable
plywood is strongest and least susceptible to water damage.
  #17
Old 05-31-2020, 04:08 PM
fresh909's Avatar
1/11 sssssss59
Thank you!
Thomas Moen
100 Paul Ave.
Waterloo, IA, 50701
319 529 6487
Hey I built the box that u designed for me and it sounds great but noticed the front panel and port are flexing quite a bit what kind of bracing and size can I add to make it stop without messing with the tuning or box volume too much
  #18
Old 05-31-2020, 04:22 PM
0/11 ssss31258
I suggest putting two 3" x 15 1/2" supports on the right and left of the port. One on each side.
This will immensely reinforce the front wall and port
Must be glued and screwed top and bottom and horizontally from the inside of your port. (So the screw heads are in the port.. not the points)
  #19
Old 05-31-2020, 04:50 PM
fresh909's Avatar
1/11 sssssss59
I have all panels glued and screwed minus the top ,the top only has a foam seal with screws every 3 inches all around the box , would threaded rod be ok to use
  #20
Old 05-31-2020, 05:10 PM
0/11 ssss31258
threaded rod is less effective and requires a lot more effort as well as the cost. What I suggested is essentially free and a lot easier
but, yes, you can do threaded rod if you want to.
fresh909 (05-31-2020)
