Can Someone design this for me. - Car Audio Classifieds!
Old 11-11-2008, 10:33 PM
worstenemy453's Avatar
Veteran Member
0/11 sssss4401
Default Can Someone design this for me.
I want a simple box that will go to specs for my soundstream T5-15, i want the loudest the specs will give me so im thinking sub back/port up
The specs are.
Net Volume Before Displacement 2.75 Cubic Feet
Vent Design 2-3" X 12.5"
Tuning Freq - 30Hz
Max power 1000 Watts
I just want a good design, this is stupid but i dont know what vehicle im putting it in yet but as small as it is, it should fit in anything i have. Someone throw me a design. Id be building it out of 3/4 plywood, Proly run 1" on the front, proly just carpeting. Someone please gimme a nice design.
Old 11-12-2008, 12:08 AM
MysticStyl3z's Avatar
0/11 ssssss113
Use 3/4" MDF (medium density fiberboard) to build it.
Old 11-12-2008, 07:40 AM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
I can do a design for you but I will need some more info.
Please click on the link below and follow the instructions.
Required information when requesting a box design or box build quote***Please read*** - Car Audio Classifieds
/ CAAA Member #2 /
Old 11-12-2008, 08:32 AM
Veteran Member
0/11 sssss4401
Would you just do the design so i could build it. Never had a problem with plywood boxes and they weigh less.
1) Car. Umm 03 Chevy Equinox Just to say
2) Subs. 1 Soundstream T5 15" - only 1
3) Power. 1000 Watts
4) Goal. I guess SQL
5) Sealed or ported: ported
6) Sub/port placement: sub back port up
7) Max dimensions:
8) Desired NET vol and tuning(optional): 2.75 cubic feet, 30Hz
9) Finnish: carpet
10) Zip code for shipping: 22485 ( i want to build it so i just want a design
11) Additional comments:
Old 11-12-2008, 09:09 AM
SPY SPY is offline
0/11 ssss10192
7) Max dimensions:
9) Finnish: carpet
Yes, I can do a design for you to build yourself. I would highly suggest 3/4" MDF, it may cost a little more and weigh a little more but there are other things to consider when picking your wood. If weight is a major concern there are other types of wood you can use but they are more expensive than MDF but particle board is not one of them.
If you want me to do a design for you I will need some idea of the dimensions you have to work with. I know you don't know what car this is for yet but I still need something to work with.
/ CAAA Member #2 /
Old 11-12-2008, 09:12 AM
Veteran Member
0/11 sssss4401
Where can i go to calculate how many cubic feet have. I would give some max dimensions but i dont wanna give u max dimensions for 1.5 cubic feet or something.
Old 11-12-2008, 09:19 AM
SPY SPY is offline
0/11 ssss10192
Length x Width x Height (all in inches)
then divide that by 1728 to get your vol in cubic feet. Don't forget you will need more than 2.75 ft^3 gross because you need to add for sub and port displacement.
/ CAAA Member #2 /
Old 11-12-2008, 05:31 PM
Veteran Member
0/11 sssss4401
How much displacement will the sub and port be. I honestly have no idea how to figure that out.
What You Think of this Design.. s Beatz General Car Audio Discussion & Questions 16 11-22-2008 04:01 PM
If you were to design a sub madmat General Car Audio Discussion & Questions 12 11-16-2008 06:45 AM
Box design help mytyeerinpie Enclosure Discussion & Design Construction Help 1 10-20-2008 07:10 AM
Box design tater Enclosure Discussion & Design Construction Help 4 10-17-2008 11:47 PM
box design for 15'' L7 ba11in Enclosure Discussion & Design Construction Help 4 09-24-2008 02:01 PM
