Box request for jeres313 - Car Audio Classifieds!
Old 01-13-2009, 11:25 AM
0/11 ssssss352
Default Box request for jeres313
1. Car. Year, Make, Model: 2008 dodge charger
2. Subs. Make, Model, Size, How many: 1 cascade designs omega 18"
3. Power. How much power per sub: 2500 watts @ 1ohm
4. Goal. SPL or SQ: SQL
5. Sealed or ported: ported
6. Sub/port placement: sub/port back
7. Max dimensions: see picture below...
8. Desired NET vol and tuning(optional): 5 cubes after all displacement
9. Finish:
10. Zip code for shipping:
11) Additional comments:
Double baffle:
Double baffle/flush mount: could you please try it with a single baffle as well as with a double baffle/flush mount to see whatthe nt volume of each would be... i would really like a double baffle flush mount.
Round over all outside edges:
45's in all inside corners: yes please
Kerfed port:
Kerfed walls:
Slanted back:
Paint inside of port
side view of box dimensions(click the top part of the picture to see the full image)... the flat part at the top i believe will be 8"... and the box will be 37" wide... thank you... let me know if you need more info...
Old 01-13-2009, 11:28 AM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Is this for a design or actual build?
/ CAAA Member #2 /
Old 01-13-2009, 11:33 AM
0/11 ssssss352
sorry brotha... thought i put it in there... just a design... the width will be 2 seperate widths... the bottom 3" of the box will be 31" and the remaining top 17" for the plate facing the tail lights and 10" for the plate facing the rear seat will be 37" due to the fact that im going to fit it over the wheel well humps.
Old 01-13-2009, 11:34 AM
ssackett's Avatar
0/11 sssss3349
Feedback Score: 21 reviews
Jeff.. Send Spy the link to the build pics i sent you of that Charger with 2 10's in a fiber glassed box.. He needs to see how to recess the bottom of the box to get the right displacememt.
2011 Street A National Champion
Sundown Audio Dealer
Incriminator Audio Dealer
Old 01-13-2009, 11:35 AM
0/11 ssssss352
sir yes sir
here it is spy...
http://www.caraudio.com/forum/showth...=charger+build
Old 01-13-2009, 11:43 AM
SPY SPY is offline
0/11 ssss10192
PM'ed
/ CAAA Member #2 /
[CLOSED PER OP REQUEST] wtb dd m1a amp spl nut 150 Wanting to Buy (WTB) 0 12-10-2008 07:55 PM
Box request for Gavriley2007 Gavriley2007 Box Requests 0 12-03-2008 03:34 PM
Box request for probmxstyle probmxstyle Box Requests 3 11-30-2008 05:53 PM
Request BLACKonBLACK98 CarAudioClassifieds' Power Seller Program 4 11-01-2008 11:31 AM
Rim request for Lincoln LS SPY Miscellaneous Stuff For Sale 12 09-16-2008 03:01 PM
