Box request for jdubbau - Car Audio Classifieds!
Old 03-28-2009, 12:32 AM
jdubbau's Avatar
0/11 ssssss268
Default Box request for jdubbau
1. Car. Year, Make, Model:
2000 GMC Jimmy SUV
x4 RE AUDIO SE 12" subs
600wrms
4. Goal. SPL or SQ:
spl with good sq if pos
5. Sealed or ported:
ported
6. Sub/port placement:
firing back subs firing up
7. Max dimensions:
38 w x 28 d x 17 H
12 cubes or so with tuning at 37hz or so
9. Finish:
Wood 3/4 MDF or 1 1/8 MDF
10. Zip code for shipping:
11) Additional comments:
HUGE 13 inch inside diameter PVC down center of box firing back if this is enough port area as PVC is 24 Inches long too!! I can put 3 stacks of MDF on each end and round the crap out of it to make my own huge aeroport!
The pvc is 14 inches from outside to outside diameter I beleive
Or Kerfed Port 90 degree and kerfed and other corners kerfed detail or explanation below.
The only special thing I want to be able to do is to take the two side panels and back panel and put two kerfs in it where the back corners would be. I would have to cut a few slots in the LONG piece to do it but I am up to it. I LIKE THIS IDEA THE BEST OR take the top Panel the back panel and the bottom panel and make all one piece with a kerf in the top and bottom fot the top to back panel and back to bottom panel so if the design is like the last time with the kerfed port firing to the rear and a port at the bottom of the box it should have a smooth curve to direct the subs pressure out.
Double baffle:yes
Double baffle/flush mount:
Round over all port edges inside and out:yes
Round over all outside edges:
45's in all inside corners:
Kerfed port:YES
Kerfed walls:Yes
Slanted back:
Paint inside of port:yes
REFS//// BOUGHT FROM
Wenn_du_weinst, SMiller, Basic1906, BRYANCAIN(TWO FI 18" Q'S), SOLD TO SPY (TC3000/LA STORM 12'S)
J-DUBB-A-U
2000 JIMMY
PRS800
LOOKING 2 BUY
LOOKING 2 BUY
1 US Amps TU600c (Hybrid Tube)
1 Diamond Audio HEX Comps
Old 03-28-2009, 08:25 PM
Ami Creations's Avatar
Loyal Member
0/11 sssss1064
You got PM
Old 03-29-2009, 12:17 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
You don't have enough space.
The dimensions you gave is 8.676ft^3 gross assuming they are outside dimensions and a single baffle all the way around.
/ CAAA Member #2 /
Box request for bumpinenvoy bumpinenvoy Box Requests 2 03-07-2009 07:59 AM
[CLOSED PER OP REQUEST] wtb dd m1a amp spl nut 150 Wanting to Buy (WTB) 0 12-10-2008 07:55 PM
Request BLACKonBLACK98 CarAudioClassifieds' Power Seller Program 4 11-01-2008 11:31 AM
