2 10" box build - Car Audio Classifieds!
Old 09-27-2011, 10:15 PM
0/11 sssss1046
Default 2 10" box build for Dodge 1500
Well i started this tonight. I'm still up in the air between picking either Sundown SA 10's, or Skar Audio VVX 10's. I'm kinda of leaning toward the Skars, simply because not many people have the 10's, and i see a lot of SA10 single cab truck installs.
But anyway, the box is 2.4 cubes net with 2 4" PVC pipes (flared at the end) tuned to 33 hz. Will finish the box in the next couple of days, but still need to sell me current sub to buy the new ones.
Anyone have suggestions on what kind of 10's i should run? I'll be putting about 1300-1400 wrms to the pair.
And, is the little "blocker bar" in front of the port a good idea with the port being only about 7" from the sub? i've had problems before with past enclosures of the port being too close and the sub unloading a lot.
Old 09-27-2011, 10:49 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
box looks great, nice an clean ports too,
i thought the skarrs had the triple stack magnet? a tall depth height?
but again you do good work
makes me wanna sand an smooth on my t-line a little more lol,
Old 09-27-2011, 10:55 PM
0/11 sssss1046
Thanks. And the mounting depth on the Skars are 6" i believe, so i'm more than good on mounting depth.
Old 09-27-2011, 10:57 PM
JMoney18's Avatar
0/11 sssss1577
I'd get the skars personally, Sa's are nice to, skar's are just a bit cheaper and still a great sub
Old 09-27-2011, 11:00 PM
0/11 sssss1046
That's what i've heard. I've also heard that they will give about the same output, but the Skars are a better low end sub, which i'm all about.
Old 09-27-2011, 11:52 PM
Prohibited Sellers/Buyers
0/11 sssss1285
I would also agree with the Skar's! I've got a build going on with the 12's and they are pretty beefy subs! I've never played with a set of SA's before, but I'm sure either route you go you'll be happy! I just went with price of new subs and re-cones to make my choice!!!
Old 09-27-2011, 11:57 PM
crownvicon26's's Avatar
0/11 sssss1882
Nice work so far on the box. It looks great!
Taramps 8k
2 Zv.3 15's
2.87:1 4th Order @ 48hz
Old 09-28-2011, 12:56 AM
0/11 sssss1046
Thanks! And i'm hoping for over a 140 with this setup. I'm still up in the air about the blocking piece in front of the port. Does everything think it's a good idea (so the subs don't unload on lower frequencies), or would it be better to not have it in there? The closest sub will be about 7 inches away from the port.
Old 09-28-2011, 01:13 AM
0/11 ssssss759
I would suggest a pair of DDs but from the 2 brands mentioned above proly not in the budget.. or airspace not available... so id say the reason a lot of people go with the SA10s is becuz they r the ISHHHH... but honestly cant go wrong with either sub both great specially for price i just TRUST sundown a lil more at this point....
Old 09-28-2011, 01:18 AM
0/11 sssss1046
Since Skar is pretty new, i haven't heard much about them. They look like very capable subs, but haven't heard anything about customer service..
Box Build: 15" SMD Box.. GetLikeMe Build Logs 19 09-11-2011 03:43 PM
2 15s "ABC" Box Build RidnClean Build Logs 48 11-06-2010 08:41 PM
Box build for 18" OZ Jacobbz206 General Car Audio Discussion & Questions 24 12-11-2009 11:47 AM
Box build for Fi Q 12" SPY Off Topic Chat 8 06-30-2009 05:18 PM
Box build for 18" Fi Q galacticmonkey Build Logs 17 06-19-2009 08:36 PM
