MopaRBumpiN's return to competition - Car Audio Classifieds!
Old 10-20-2011, 05:18 PM
MopaRBumpiN's Avatar
0/11 sssss3819
Feedback Score: 35 reviews
Default MopaRBumpiN's return to competition
Today marked my official return to competition!
I will competing in the TeamNorthEastSPL league in the WooferCooker 1 and Bass Brawl 280 class
The equipment going in my ride (2008 Dodge Avenger R/T) is as following:
Pioneer AVH-P3200BT
(2x) RE SX 10s
SounDigital 5000.1D
XS Power D6500
Knukonceptz and Stinger wiring
This build log is the first time I built my own box. I have never before built my own box nor design one. This time I did both :-)
The box specs are as following:
2.26 ft^3
for comps, 8" aero tuned to 47 hz
for daily, 6" aero tuned to 36 hz
Onto the pics!
My ride:
Box Building pics:
Box should be finished this weekend. Hopefully everything will be installed within the next couple of weeks
Team DefJ, Team XS Power, Team Audio Technix
Headunit: Pioneer DEH-80PRS
Tweeters: Vifa XT25
Midbass: Silver Flute 8"
Highs Amps: Soundstream TN4.900
Sub: Cascade Design Omega 15"
Sub Amp: Incriminator Audio 20.1
Electrical: XS Power D2400, XS Power D3100
Deadener: Alpha Damp and Audio Technix 80 mil
Old 10-22-2011, 05:42 PM
0/11 sssss3819
Pics of the equipment:
Subs:
Amp with Toolmaker Aluminum Dual Inputs:
XS Power D6500 with Toolmaker Distro Blocks:
Faceplate setup, talk about a tight fit!:
Faceplate being glued:
Box test fit in my trunk:
Battery holder beginning to be constructed:
Battery holder with frame to level everything:
False floor in and battery wired up and strapped down:
Back windshield:
Tweeters: Vifa XT25
Old 10-23-2011, 02:22 PM
0/11 sssss3819
Small update for today. Was able to resin the box. Sanded everything down so all boards were flush with each, then I resin'ed both the inside and outside of the box.
Pic of the inside of the box:
Pic of the entire box being resin'ed:
Added a distro for my remote line:
Small update but an important one. Just waiting on my ports to arrive and box, subs, and amp will be mounted and wired.
Tweeters: Vifa XT25
Old 10-23-2011, 07:27 PM
0/11 sssss3819
Got the first layer of paint on the box. Will get the second layer on Tuesday (suppose to be in the 50s and sunny so should be a good day to paint). Hopefully get the 8" aero painted up too (at least the flare portion). Gonna order the 6" aero tonight so that should be here sometime this week.........hopefully.
Got 2 of the 3 parts done in the big 3. Was able to get the alt to battery positive and battery negative to ground done.Still gotta do the engine block to chassis.
Tweeters: Vifa XT25
Old 10-23-2011, 11:18 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
Nice. Job on the build bro. Keep it up
SHABAM
Old 10-23-2011, 11:21 PM
Zooook's Avatar
1337 M3mb3r
0/11 sssss3991
Feedback Score: 31 reviews
Lookin good
How many 6500's to run that sd5k?
ALL FOR SALE ALL FOR SALE PM ME FOR PRICES
2003 BMW 330I
2x12" AB HD/W DC XL recones
Old 10-24-2011, 06:39 AM
0/11 sssss3819
Originally Posted by Zooook View Post
Lookin good
What you see is what you get lol
The league I compete in limits your battery power. I'm allowed up to a d3100 but the best I could afford was the d6500.
Tweeters: Vifa XT25
Old 10-25-2011, 02:04 PM
0/11 sssss3819
Finished the box today! Got the subs mounted, wired up,and the port mounted. The way it sits with the 8" aero, tuning is in between 50-51 Hz. Within the next week or so, I will be testing for my resonant frequency via the sealed box method. Once I know where my car peaks, I'll drop the box and cut the port to the correct length to generate the appropriate peak for my box. Ordered my 6" aero last night so once I get that, I'll cut it to the correct length so I can be able to fit the box and port inside the trunk and be able to close my seats. Once I get all my ports to the correct lengths, I'll be painting them bright a$$ yellow so it stands out lol.
I soldered the two 8 gauge wires to one 8 gauge wire in order to simplify wiring.
Anyone know how to remove caulk from my port? I have used knives, acetone, sand paper, scrubbing like no tomorrow, and just trying to peal it but its not all coming off.
Tweeters: Vifa XT25
Old 10-25-2011, 06:38 PM
0/11 sssss3819
Well got everything installed today!
At first, where the box was sitting, I couldn't mount the port so I added 2x3s on the bottom of the box to lift it up some. Did the trick.
Did some testing also. Did a 144.3 at 52 hz on only a 1 sec burp. My headunit's input voltage is too high so it was causing the amp to protect at my burp volume. Time for a new amp!
Tweeters: Vifa XT25
Old 10-26-2011, 12:47 PM
DonH's Avatar
0/11 sssss6645
aint you selling the amp?
SHABAM
MopaRBumpiN's sound system log MopaRBumpiN Build Logs 5 07-14-2011 01:42 PM
return of dc in the bmw!!! Zooook (DC) 20 03-18-2011 04:00 AM
Return terra General Car Audio Discussion & Questions 45 03-09-2011 09:47 PM
The return DUMPED Build Logs 131 11-22-2010 07:11 AM
The Return Of The Man G-String BassikInstincts Uncensored Off Topic 2 02-26-2010 02:23 PM
