Sonata 2012 Turbo Build Log - Car Audio Classifieds!
Old 11-07-2011, 02:20 PM
0/11 ssssss244
Default Sonata 2012 Turbo Build Log
It's my first time doing a build on a new car. It totally freaks me out but i still know i'll do a better job than pretty much every car audio place around here. It will start slowly but be update each time i makes some progress. Not alot of free time and Quebec winter makes it impossible to work outside...
My car: Sonata 2.0T Limited 2012
Nice car for a good blend of confort and performance. Motor is a GDI 2.0T 274hp/269lbs torque. It's my first new car and i'm gonna take care of it. For that reason, i decided i'll this build would be more reasonable in term of loudness. First i don't want to destroy my new baby, second i want to keep the weight down as much as possible....
Car is fully equiped except for the nav... it didn't worth the additional 3k to me (and canadian price are a joke compared to yours!!! )
Stock system is pretty impressive to say the least. It's being called Dimension, but it seems to be a hyundai's brand.
there's so midrange drivers over the dash and 6.5 midbass /midrange speakers in each front doors. A pair of coxial in the rear doors and a free air 8inch in the rear deck. All powered by a stock amp (on limited model). I could have lived with this system if i wasn't as crazy about audio, it really have a balanced sound to it.
But i'm not like this so i add to do something I'll still keep the Stock Radio because it control pretty much everything in the car. No way i'm putting the ugly avic 900bt there....
System will be more sq oriented than my last. I want to make everything perfect so i just instal it now and resist the temptation to modify it every six month
First Trunk Car ever!!! i wouldn't even look at trunk car before because of system consideration.... now priority changed. I'll just use a single 12 in here
Now the Equipment:
Stock Headunit with wheel control,bt,voice recognition. Gps for maps!
Frontstage: Focal 165k2p
Electrical: Everything Stock. Will do the Big 3 as the summers come up next year. 0ga knukoncept wire from the front to the back. No additional batteries planned here for weight purpose
I might change the stock battery for a g31 agm...
Frontstage amp : Arc Audio Foose 150.4 (rated 320x2 brided)
Sub Amp: Id Q1200 I just bought in here
Sub : Tc sound 3hp, dual 3ohm. A prototype
Processor: Alpine PXE-h650 with imprint (first time with a processor)
Deadener : 100ft/sq of damplier. At the antirust they did has something inside the lower doors panel so i don't know i'll be able to work out there... i'll see later i guess
Old 11-07-2011, 02:21 PM
0/11 ssssss244
Processor:
More pics of the Sub
At the moment i'm still waiting for my 100ft sq of damplifier, my Sub Amp and and amp to replace my Arc audio 4150 in my old car. It's now the girlfriend car and she's not that much interrested in highend system
She still has something fine tho, just not what i used to have in there
The Following User Says Thank You to xprime4 For This Useful Post:
bassheadA (01-08-2012)
Old 11-07-2011, 02:41 PM
jcp0420's Avatar
0/11 sssss2117
Man thats gonna be a nice build and that car is pretty damn nice for a hyundai. How well does she drive?
Old 11-07-2011, 06:18 PM
0/11 ssssss244
Wonderfull. Plenty of power and not so bad mpg. Actually it's rated for 24/34 or something like that but i'm not getting that for now. It's really confortable and got a shitload of option in it. I was also considering an 2012 Altima V6, but i liked every little thing of the 2.0T alot more.
Amp for girlfriend car should be here this week, sub amp prolly next week and deadner too. I'll probably start in a week or so
Old 11-10-2011, 05:28 AM
0/11 sssssss16
Its going to be a nice build it should good.. Those car have alot of elect in them so be careful u could void ur warranty...
Old 11-10-2011, 06:02 AM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
tuned in!
Old 11-13-2011, 12:04 PM
0/11 ssssss244
I just did a first look to check how i'll be wiring the processor to the actual stock system.
It seems like the signal from the headunit come as an Spdif out into the amp. there's no way i can get away without first going into the stock amp, then into the processor then into the aftermarket amps. I'm not sure i'm loving this....
I don't even know if the stock amp has x-over before they go to each speakers... it seems like the midrange speakers in the dash got a little resistance on them, which might be a good thing if i understand what they did well
Too bad there's no reference thread for that car
Old 11-13-2011, 10:14 PM
Beerdrnkr's Avatar
0/11 sssss1231
nice sub u have there. looking forward to the build, hopefully u dont do what i did when i bought a new nice vehicle and have the need to upgrade constantly.
Old 11-14-2011, 12:29 AM
0/11 ssssss973
nice, should be clean
Old 11-14-2011, 12:59 PM
0/11 sssssss81
Get started already! Love that car and equipment.
build log for the gf mcmuffin Build Logs 7 10-27-2011 09:21 AM
Comments for the 1994 Dodge Stealth R/T turbo Build Log 2fnloud Build Logs 0 05-02-2011 10:01 AM
This is my first build log! Bradleyj0808 Build Logs 53 03-31-2011 10:40 AM
SPL_II's Team CACO Build Log <--- First real Build! SPL_II Build Logs 123 09-23-2010 08:44 PM
MY RV build log =] kingsuv Build Logs 20 11-16-2009 06:39 PM
