enclouser modification... - Car Audio Classifieds!
Old 11-09-2011, 10:22 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Default enclouser modification...
Ok, so I built this box probably 3-4 years ago for my girls car. I built it specfic to an Audiobahn amp which looked great with the chrome. Well I ended up stealing the amp from her ride to use in mine for a short time. Long story short I ended up frying the amp somehow...
Anyway, her birthday is coming up and she has been begging for bumps again...So I thought I would accomidate her
So here are a few pics I took of the modification I'm doing. I plan on making an "insert" to kind of blend the areas of the old amp shape with the placement of the new amp. I'm going to incorperate pink GF vinyal with a matte black paint or vinyal.
I don't have any of the old pics on my computer right now, but I will try and dig a couple up to give you an idea of what it used to look like.
Here I added the LTP to form a steady radius.
Then I glassed it in place to keep it solid.
A little sanding.
Here are the 2 pieces that will be stuck together in the end.
Old 11-10-2011, 09:36 AM
Ja Marcus
0/11 sssss6975
Here is what it looked like at one time.
Old 11-14-2011, 09:02 AM
Ja Marcus
0/11 sssss6975
Alright guys. I was able to get a lot done on this over the weekend. Between building my Jeep and this I was beat from all the kneeling,bending,sanding,whatever.....I think I'm getting old! LOL
Anyway, on to some pics...
Getting things ready to be bonded together.
This piece will be the secured to the other one.
Here is my special brew.....
Stuck together.
Old 11-14-2011, 09:11 AM
Ja Marcus
0/11 sssss6975
After everything cured over night.
Time for some filler...
Green stage sanding.
More filler.
After a while sanding this is what I ended up with.
And here it is without all the tape to give you a better idea.
Amp cooling modification. LyferXB9s Member Rides & System Pictures 36 08-20-2011 05:03 PM
Dual 15" enclouser audioarsonal Wiring, Electrical & Other Installation Equipment 7 06-16-2011 06:29 PM
Modification on a Memphis 4k zlibby76 (db-r) 28 04-01-2011 08:16 AM
4th order enclouser budowens83 General Car Audio Discussion & Questions 4 03-19-2011 04:24 PM
pwk design modification help bottlefed1 Enclosure Discussion & Design Construction Help 48 03-09-2011 07:43 PM
