VW GTi 337 install - Car Audio Classifieds!
Old 11-14-2011, 11:55 PM
Bsktbll895's Avatar
0/11 ssssss189
Default VW GTi 337 install
-Volkswagen GTi 337 full system install.
-Items installed---> RE Audio XTX800.4, Kicker 750.1, Infinity kappa 60.9cs component set (front), Infinity kappa 62.9i two-way (rear). AQ SDC2.5 15, JVC touchscreen. Big 3. --John bought the AQ sub off of craigslist and after I loaded it and began testing, found out the bottom spider was completely detached from the former causing a rubbing sound, so I sold him my IA flatlyne 15 and was very happy.
*Not everything listed is pictured throughout the install due to very tight time constraints*
The RE amp was basically the exact same dimensions of the stock VW amp so I was able to mount it in the existing area along with the crossovers.
Dont ask how I fit the huge kappa tweeters in the stock door area. I just did
VW GTi 337 install - YouTube
04 Impala walled 4 15s
-Andrew Traumasetters White
Old 11-18-2011, 01:32 PM
0/11 ssssss249
great install is it true tht its louder in a hatchback car then a trunk car
Old 04-07-2012, 07:36 PM
0/11 sssssss51
I'm bringing this back from the dead because I had a 20th Anniversary GTI, which is nearly identical to the 337. I am curious how you got the tweeters mounted; I had fairly shallow tweets in mine, and it was still a bitch and a half to mount. The stock amp location was perfect for the crossovers, but I couldn't fit my high pass amp in there like you did.
Clean install vs Loud install linden General Car Audio Discussion & Questions 32 12-23-2010 06:55 PM
WTB Fluke 337 MisterGrubbs Wanting to Buy (WTB) 6 12-16-2010 11:56 PM
Uses for Fluke 337 Clamp Meter jimmyjohns General Car Audio Discussion & Questions 6 10-21-2010 05:01 PM
Razer Gaming Give Away of 1,337 combo packs!!! bangin hoe Technology & Computer 9 10-03-2010 11:09 PM
