Hummer H2 4th ORDER BANDPASS 8 nightshade vs2 15'S BY SCOTT BOWMAN - Car Audio Classifieds!
Old 12-24-2011, 05:56 PM
ty_houston's Avatar
0/11 ssssss393
Default Hummer H2 4th ORDER BANDPASS 8 nightshade vs2 15'S BY SCOTT BOWMAN
This is on a few other forums as well, was bored, and I'm actually on this site more than smd, so I figured I would post the log here as well. Equipment as follows;
8 Sundown audio nightshade vs2's 15's dual 1ohm
2 audioque aq20k's
2 old school precison power pcx channels
8 kinetik 2400's, 2 shuriken bt120's and one kinetik 2000 under the hood
2 mike singer 350 amp alternators
mla dual alternator bracket
mla missing link module
pair of sundown audio neo 10's in custom doors built by scott bowman
pair of selenium super tweeters
custom a pilars with 4.5 infinity ref comps
q-logic kick panels with fosgate power series comps
one bad as 4th order designed by Scott Bowman and Nick Probst..
a ton of 1/0 welding cable(ofc)
alpine ina w900
cheap clarion eq(but I love it)
Thanks to Jacob from sundown for making a bad as sub, and thanks to Vance Wilkie for installing my alts, and fixing shit that was broken.
old set up
tear down"
Scott bowman
sketch up of new box
loading wall
These are the first subs we tried in the hummer, american bass hd's. They are good subs, but they don't perform well in 4th orders. They have a low qts and are stiff as hell, better suited for ported or 6th order's. Mike Singer had told me this last summer..eventually went to the nighshades
shrunk the port to lower tuning
best number with the hd's, door open on the dash
clamp numbers with the hd's..a little over 22k ,,a hair under one ohm. funny, clamped about 3500 less watts once we changed subs, my rise went up, power went down, but score went up almost 2.8 db
This is why I changed subs
bad recone, not enough glue on the stitching
Sub blown on 22k - YouTube
new subs
upgrades:
before
after Mike Singer 350 amp alts x2!
8 nightshade v2 15's 4th by Scott Bowman
10 sundown neo 10's, 6 st200 super tweets
2 precision power pcx 4125(mids)
2 phoenix gold xenon 200.4 (hi's)
2 Stetsom 14k2e's @ half ohm
2 singer 350's 13 kinetic 2400 2 batcap 4000's
Old 12-24-2011, 05:59 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
i love this build
-Youtube Channel
The Following User Says Thank You to taylorpro For This Useful Post:
ty_houston (12-24-2011)
Old 12-24-2011, 06:03 PM
ty_houston's Avatar
0/11 ssssss393
H2 hummer 8 sundown nightshade v2 15's 2 aq20's - YouTube
Ty Houstons H2 hummer outlaw testing - YouTube
best numbers with nightshades so far is 156.5 sealed on dash at 41hz? 160.5 outlaw at 43hz, haven't retested since installing the Mike Singer alts, plus Scott is running more runs of 1/0 next week, so hopefully the scores will improve
Old 12-24-2011, 06:17 PM
HACKMUNCH's Avatar
0/11 sssss3892
What #s u get with hd 15?
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
Old 12-24-2011, 06:19 PM
Skip01's Avatar
Ladies MAN
0/11 sssss5551
157 in pic
Youtube VIDz :
Old 12-24-2011, 06:28 PM
ty_houston's Avatar
0/11 ssssss393
155 flat sealed on dash at 48hz
157.8 drivers door open mic on dash 44hz
159 outlaw mic in the kick 42hz
above numbers with hd's and 22k clamped from the aq20k's
0/11 ssssss395
That a super charger i see
ford focus (the black fucus)
build in progress
Old 12-24-2011, 06:33 PM
ty_houston's Avatar
0/11 ssssss393
yes, its supercharged, before I added all the caraudio it was quite fast for what it is, with the weight and the wheels, I'm betting its like a stock hummer again, the charger does help with motor bog from the two alts while under a load from the 20k's
Old 12-24-2011, 06:53 PM
chrishova's Avatar
Eight 12''s
0/11 ssssss703
Looks good, Ty, 160+! Can't wait to hear it! There are hard hitters in VA!!!
-- Sent from my Palm Pre using Forums
'97 Grand Prix GT 3.8
5 Black Cherries
Eight SA 12''s on a DDz2
The Following User Says Thank You to chrishova For This Useful Post:
Old 12-24-2011, 06:58 PM
HACKMUNCH's Avatar
0/11 sssss3892
ok thanks man, so you gained 1.5db with nightshades. legal of course because thats all that matters.
TEAM TSA 2013
FACTORY BACKED
8 12s-4th order bandpass SUBW123 Build Logs 11 03-30-2011 02:42 PM
Mikey's Hummer H2 Build Log - 8 15's, 6th Order Bandpass kane0249 Build Logs 32 08-08-2010 10:29 PM
4th order bandpass? wahvtec Enclosure Discussion & Design Construction Help 0 06-28-2010 04:53 PM
4th order bandpass users come in! murderedtahoe General Car Audio Discussion & Questions 19 04-18-2010 05:21 AM
