jhg33k's winter build starting - Car Audio Classifieds!
Old 12-27-2011, 05:13 PM
jhg33k's Avatar
n00b looking to learn...
0/11 sssss1531
Feedback Score: 31 reviews
Default jhg33k's winter build starting
Well I've been piecing this together for a few months now in anticipation of my winter break from work and have just about everything I need to get rolling! I started on building the box today which will be dual tuned for 8.5ft^3 tuned to 38hz with all ports open, and 9.3ft^3 tuned to 30hz with the center port plugged. These are split slot port along the bottom and subs firing up...will be building another soon though to try subs forward and port up
Equipment being added is:
2 more runs of Knu KCA 1/0 - Total 3 runs of each + and -
2 more Group 31 Deka's - Total 3 Group 31's and a Deka group 34/78 under hood
Mechman 270 alt - Replacing Powerbastards 250 amp
100ft of Knu 12 gauge Karma Bi-Wire
8 Gauge Knu Karma Speaker for subs
6.5" CDT Com-626's in all 4 doors - Replacing Polk DB651's
DC 175.4 to run CDT Components
DC 5.0K @ .5 for Subs
2x 18" DC XL's D2
80 sheets of Damplifier (may not go in until summer though...kind of hard to work with in the middle of winter lol!)
Toolmaker Dual Inputs for DC 5.0K so 2 sets!!
Lots of Vinyl that may not be put on until after the snow stops flying!!
About to do some running around but will post pics shortly...hoping to have this build finished within the week if all goes well!!
|2011 Toyota Carolla S |2 Mmats HD4000.1's | Pair DC XL 12's w/AR cones | Average headrest score out of the trunk...will update after world finals
Old 12-27-2011, 05:17 PM
Bushj311's Avatar
0/11 sssss5532
Feedback Score: 45 reviews
Give me a shout if you need a hand. Id like to check it out
Old 12-27-2011, 05:20 PM
jhg33k's Avatar
0/11 sssss1531
Will do man...I still have to see you about that 4 gauge too! Will you be busy this weekend? I have a meter too if you'd need to get metered sometime...
Old 12-27-2011, 05:28 PM
jhg33k's Avatar
0/11 sssss1531
Old 12-27-2011, 11:49 PM
jhg33k's Avatar
0/11 sssss1531
Moar pics of the equipment going in!!
Old 12-28-2011, 12:59 AM
treylittlefield's Avatar
0/11 sssss5201
Feedback Score: 37 reviews
Good start. Tuned in
Sent from my C771 using Tapatalk
2000 2dr Blazer
Old 12-28-2011, 05:34 PM
jhg33k's Avatar
0/11 sssss1531
Got to put in more work on the box today...the top is sitting on it but I haven't glued/screwed/clamped it yet. That should be done in the next day or so....
This box will also stay below window line / rear seat height to keep me in Street/Meca!
Old 12-29-2011, 11:33 PM
jhg33k's Avatar
0/11 sssss1531
So I had to actually work today even though I was supposed to be on vacation until Jan 3rd so I didn't get as much done as I hoped but did completely finish the box! I'm not covering it or making it look pretty...just want functionality!
And mind you this is only the second box I've ever built so take it easy on me lol! I thought I had a pretty good idea for the port plug as well and so far it seems like it will work well! I didn't want to have screws going in and out of it all the time and don't like T-nuts because phillips heads just deteriorate after a few ins-and-outs.
On to the pics!
Old 12-29-2011, 11:44 PM
0/11 sssss5201
i actually like the port plug idea....its different
2000 2dr Blazer
Old 12-29-2011, 11:46 PM
jhg33k's Avatar
0/11 sssss1531
^^ Thanks man! I know it will be in and out a lot so I didn't want to tear up the box too badly so this is what I came up with...tighter than a...well lets keep it g-rated lol! It fits tight but I may still need some tape around the edges. I'll find out once the subs are playing hopefully in the next day or so!
The Following User Says Thank You to jhg33k For This Useful Post:
05TRAILBLAZER (01-04-2012)
Winter Build log Kyle K Build Logs 11 01-11-2011 12:41 PM
Winter Build Kyle K Build Logs 16 10-18-2010 10:59 PM
starting my build soon Ccab81 General Car Audio Discussion & Questions 19 01-28-2010 03:18 PM
Starting new build NCheever Build Logs 2 10-15-2009 11:04 AM
