db's new years eve build! - Car Audio Classifieds!
Old 12-31-2011, 07:52 PM
0/11 ssssss247
Default db's new years eve build!
Ok I cheated a little. I started a couple nights ago getting the pieces cut. I glued the main panels together and clamped it up.
Now getting to the details.
I'm using a 6" aero from derrick. I routed out the panel to flush mount it. I wasn't happy how there was a huge hole on the backside and nothing but the small flange to seal up. So I made a second panel and routed it the size of the tube.
How it looks on the backside
More to follow...
Old 12-31-2011, 08:00 PM
0/11 ssssss247
Jumped ahead of myself.
I suppose I should back up and tell what I'm building.
I got a good deal on a proto from Jacob to replace my sa-8. This box is being built out of 13 ply birch. It's my first build on birch outside of a tv stand I made a while back. It's for sure a lot less messy and lighter weight. I had to buy a new blade for my table saw as the 36T just chewed it up. I'm now using a 80T and works much better.
The specs are 1.85 cft3 after displacements and tuned at 31hz. I designed it to fit in a narrow space which is why it is long and shallow.
Working on the rest of the bracing and fitting the port now.
Old 12-31-2011, 08:59 PM
oslouie's Avatar
0/11 sssss5073
Feedback Score: 69 reviews
Isn't 1.8 too big for an sa 8?
Sent from my EVO 3D using Tapatalk
Old 01-01-2012, 12:55 AM
0/11 ssssss247
Yes it would be. This is a 12. More pics are uploading.
Old 01-01-2012, 11:37 AM
0/11 ssssss247
Got the port mounted. I wasn't crazy about the green so I sprayed it with 5 coats of hammered black. Turned out pretty well I think.
Bracing is put in as well. I used it as double duty to help support the port. It was a little tricky to get them mounted at the exact height I wanted. It had to support the port but too high and it pushed it out and too low it didn't do anything. So I set them in place and traced them with a sharpie. Then used a small nail and then used a small hammer to tap it from the inside out to mark the hole. Worked pretty well.
Here it is with the port installed. I used heavy duty pvc primer and cement, then double wrap of hvac tape. I wanted to be sure it was sealed and secure. Would be next to impossible to repair once it was all together.
More to come.
Old 01-01-2012, 11:40 AM
0/11 ssssss247
Double pic post. Not sure why I can't edit. Anyway here is the port mounted pic.
Old 01-02-2012, 09:27 AM
0/11 ssssss189
HOLY PORT!!! Looks good though bro!
99 Suburban 2wd w/5.7L
2 Singer ext reg alts-270a & 300a
HU-Pioneer 80prs
XS-3400D & 5-XP3000's
4-18" Fi Sp4's c-pillar 4th/bandpass
2 Banda 7k's
Old 01-02-2012, 11:55 AM
0/11 ssssss247
Thanks!
It's done! Stayed up last night and got it finished.
Here are the pics
Sub:
Double baffle:
Binding posts I made:
Old 01-02-2012, 11:57 AM
0/11 ssssss247
Mounted:
Top double baffle with roundover edge:
Took it for a test ride last night and very impressed. I still need to tweak my ssf and gain since it was set for the sa8.
May have some videos to share later.
az - NEW YEARS EVE BASH hosted by Stereo Joe. Subzero Competition Corner 0 12-31-2011 08:57 AM
Mad DB's and SQ westman995 General Car Audio Discussion & Questions 20 09-23-2010 01:52 PM
How many Db's does it take to be fatal to a human? AutoMediaPro General Car Audio Discussion & Questions 8 09-11-2010 10:43 PM
The all halo's eve sub build( splvictim20 Miscellaneous Build Logs 19 04-18-2010 12:03 PM
Merry Xmas Eve everyone!! brtnboarder3241 Off Topic Chat 0 12-24-2009 02:03 PM
