Ford Escape - Car Audio Classifieds!
Old 01-21-2012, 01:15 AM
Esoteric's Avatar
0/11 ssssss259
Default Ford Escape
Any members done a build on a ford escape? I've only found one on here so far. I'm lookin for ideas, suggestions,anything really.
Old 01-23-2012, 09:37 AM
Esoteric's Avatar
0/11 ssssss259
Anybody?
Old 01-23-2012, 09:41 AM
0/11 sssssss81
im in the middle of a build in a 2008 ford escape. 2 AB XD 15s in a 6th order non wall on a bc2k. what do you need? if you're looking for the car's resonant frequency i have no clue
99Bonney's Avatar
0/11 sssss6246
Yea I've done a couple in mine. Just bumped it to the top for you.
99Bonney -> *** 2010 Escape Build *** PSi+DD
2006 Tahoe
Subs- 4 Crossfire xs v2 15s
Amps-Crossfire 8k
Batts- 6 xs 3100s, 2400
Alts- 3 Mechman SMD 340s
Old 01-23-2012, 09:53 AM
Esoteric's Avatar
0/11 ssssss259
@ 99Bonney I seen yours i really like it but im trying to make it so that the box is not so tall. Im want it to be a little lower, bout middle of the headrest.
@ Redeemer 360 Have you already posted build pics of yours?
Im not really sure of what exactly i want. Im not even sure what subs im gonna use. Im looking at the AQ sdc 2.5 maybe 4-12's or 2-15's.
Currently im runnin 2 Massive Audio 15's in a pre fab vented box they sound good but specs call for small sealed so may see if it would b possible to squeeze 4 of those back there.
Any help or advice is much apprecaited.
Old 01-23-2012, 10:00 AM
99Bonney's Avatar
0/11 sssss6246
If your cargo area has the same dimensions as mine you wont be able to fit 4 12s on the baffle. Its not deep enough. My box dimensions are 40.5 wide, 22 deep and 23.75 tall. You could do 2 15s in a nice big box or 2 18s in a relatively small box. I can get about 9.5 after disp when I invert my subs.
2006 Tahoe
Amps-Crossfire 8k
Old 01-23-2012, 10:15 AM
Esoteric's Avatar
0/11 ssssss259
This is where i got the idea for 4-12's.
http://www.cardomain.com/ride/3215053/2003-ford-escape
I dont want to do 18's im trying to stay with the 12's or 15's. Idk im still deciding. I will definitly be picking your brain for ideas and advice.
Old 01-23-2012, 10:16 AM
Esoteric's Avatar
0/11 ssssss259
Yes i think the cargo areas are exactly the same.
Old 01-23-2012, 10:23 AM
99Bonney's Avatar
0/11 sssss6246
Hmm I will have to check again to see if 4 12s will fit. His install is pretty much exactly like mine. Batts sit in front of the box but the amps I have underneath the box. If you pull your carpet up is there a plastic floor with the jack? If you take that out you can get another inch or two in height.
2006 Tahoe
Amps-Crossfire 8k
Old 01-23-2012, 10:55 AM
0/11 ssssss327
I did 2 12 s in my wife's 06 but it wasn't anything big rd 1000 and 2 sonances port faced the back as that's we're it sounded the best after a little deadening I don't no if I have any pic as its been a while
04 Ford Escape 2 Sundown z15 v1s Part1 llacrazyhair Car Audio Videos 1 08-20-2011 01:47 PM
2010 ford escape 99Bonney General Car Audio Discussion & Questions 1 03-26-2011 07:48 PM
alt for 2010 ford escape hybrid 99Bonney General Car Audio Discussion & Questions 1 02-08-2011 08:05 AM
2002 Ford Escape wishIwasLOUD General Car Audio Discussion & Questions 1 11-10-2010 05:36 PM
2005 ford escape Toone General Car Audio Discussion & Questions 1 09-13-2010 04:25 PM
