Kerf Box Build for 2 DD 1508 - Car Audio Classifieds!
Old 01-23-2012, 08:44 PM
0/11 sssssss85
Default Kerf Box Build for 2 DD 1508
Wanted to build a box for a pair of DD 1508's I had lying around. Designed the Box to be 2 cuft tuned to 34 Hz.
Boxes overall dimensions are 21.5 x 20 x 14.5 with a 1.5" port opening.
Sketched up the box first to see how I liked it.
Started doing the kerf and made the brace.
After getting all of that done I rounded it over onto the brace and started fiberglassing all the kerfs.
And Finally here's a Mock up of what it should look like minus the wings
Had to stop due to lighting. Will finish fiberglassing the back and then I will button it up and cut some holes.
Old 01-23-2012, 08:46 PM
mega fatty
0/11 sssss6008
very nice looks sexy!
07 mazdaspeed3
rd d9 @ .5ohm
Old 01-25-2012, 08:56 PM
0/11 sssssss85
Here's a shot of the DDs with the large carbon fiber dust caps
Have the kerf all bondo'd up and ready to roll
Then I got to finishing it up. Screwed and glued all the boards together. Heres a shot of it being tested in my car.
Had it wired to my IA 40.1 @ 4 ohms. For 2 8's they get down and are loud.
Then onto making it pretty, heres the finished product.
Old 01-25-2012, 09:06 PM
e2theloc's Avatar
0/11 ssssss909
thats a funny looking box. wonder if it lowers your box rise. got a clamp?
Old 01-25-2012, 09:08 PM
0/11 sssssss85
yeah, ive been wondering about that too. i'll clamp it tomorrow
Old 01-26-2012, 04:10 PM
Matt3824's Avatar
0/11 sssss3754
Unique, but very awesome. I really like that box. Nice work.
How do you determine the radius of the kerf/ distance between each cut?
Old 01-26-2012, 04:21 PM
0/11 sssssss85
This box was easy. For other kerfs I make an arbitrary number like a 5" or 6" radius. Since this was a half circle, and I knew that the box was 14.5" tall with a port operning of 1.5", my diameter would be 12.25". Circumference is Pi*D and I need half of that. So my kerf length is 19.23" and you make 11 cuts for a 1/4 radius so I need 22. 19.23"/22 is .87". Thats how I made my kerf, other people have different methods.
Old 01-26-2012, 04:49 PM
newarkbeast973's Avatar
0/11 sssss7810
Looks kind of big for 2-8's. Looks good though.
New build coming soon!!
Old 01-26-2012, 05:24 PM
0/11 ssssss247
nice work man
Old 01-26-2012, 10:09 PM
0/11 sssssss85
The box is only 2 cuft before sub displacement. DD recommended 1 cuft for each 8
Dual Kerf and Plexi Build DonH Build Logs 34 12-23-2011 09:23 PM
Enclosure Build: Dual-kerf port, 12" Avalanche Pioneer~Saturn Build Logs 59 11-02-2011 08:27 PM
Build: Dual Kerf Enclosure for LVL 4XL 12's DonH Build Logs 24 03-31-2011 02:22 PM
Build log for Juan651, Single 18 NS, double kerf....3kw iamamp3pimp Build Logs 4 03-24-2011 03:42 PM
Enclosure Build: Dual kerf, Gbo's 4 SA-8s Pioneer~Saturn Build Logs 81 03-10-2011 04:58 PM
