team sundown escalade wall build - Car Audio Classifieds!
Old 02-08-2012, 08:45 PM
Veteran Member
0/11 sssss3359
Default team sundown escalade wall build
okay guys. the new zv3 motors showed up today so i guess it's time to show some pics. I am gonna be walling off 4 zv3 18's. i have 2 3500's right now however i may decide to put 2 more on them when finished. currently waiting on epicenter designs to have time after sbn to do my door panels. They will each house 2 8's, 2 6.5's, and 2 tweets. i'll also be doing a kick with a 6.5 and tweet as well. And i will also be replacing the factory speakers in the center counsel with 6.5's. Everything will be ran off a sax200.4. I finally have everything in my possesion so the only thing that is holding me up is having the time to build the wall. I have been swamped at work and was kinda wanting to wait until it warms up a little bit. Anyways just wanted to get this build log started and post a few pics tonight. Hope you guys enjoy!
Old 02-08-2012, 08:52 PM
0/11 sssss1184
Looks good bro
Old 02-09-2012, 09:15 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Your running all the mids off one 4 channel? I would look into at least another 2 channel for the 8's or tweets.
Old 02-09-2012, 09:38 AM
Veteran Member
0/11 sssss3359
I might end up doing that. The 200.4 definitely has plenty of power to run all of them
The Following User Says Thank You to woofer cooker For This Useful Post:
KNOTDUDE (04-16-2012)
Old 02-09-2012, 09:40 AM
Ja Marcus
0/11 sssss6975
Yes it has the power.That's not my concern, I'm concerned that you will either be running the 6.5's and 8's via the same signal. Or the 6.5's and tweets.
With a separate 2 channel you can at least feed them all their own signal.
Old 02-09-2012, 09:46 AM
Veteran Member
0/11 sssss3359
Agreed. I was just thinking about possibly crossing the tweets off with a seperate x'over but ill probably just end up buying another amp. I'll have to see how much room I end up having on the back of my wall. I'll have batts at the bottom and the 2 3500's and a 200.4. Possibly 2 more 3500's. So more then anything the space is gonna become the issue.
mega fatty
0/11 sssss6008
Well if he crosses all the mids at reasonable points for their mechanical limits it should be fine
But a 2 channel would be ideal
07 mazdaspeed3
rd d9 @ .5ohm
Old 02-12-2012, 03:43 PM
Veteran Member
0/11 sssss3359
built 2 of my woofers yesterday. wish the parts were here for the other 2 so i could've done those too. Anyways here are some more pics of the sexy little things. and i unboxed my 200.4 for a couple quick glamour shots. you can tell how big of a beast it is next to the 18's! oh and be sure to check out my beautiful glue joints
Old 02-12-2012, 03:45 PM
Veteran Member
0/11 sssss3359
and here's a pic of my truck up close. cant wait to start this wall
Old 02-13-2012, 07:26 PM
Dbmonster's Avatar
0/11 sssss1217
Is your 'lade black or blue? I have a riptide blue one and was planning on getting those same wheels. are yours 24's or 26's?
WARNING: Due to high sound pressure levels, all passengers are encouraged to remove any and all tight or restrictive clothing such as bras, thongs, etc. before entering this vehicle.
Mazda 6 | Team Sundown 2011 Build | AA-Foo Uninterrupted Build Logs 15 04-26-2012 02:27 AM
Resko1's back team sundown Metro build resko1 Team Sundowz 340 08-01-2011 06:03 AM
Team Sundown Russia adds some beat to an Escalade Skillz (Shok Ind) 8 05-10-2011 09:49 AM
team vxincar tunnel wall build 12x 12s and 9k of power astra van w reg 2000 vxincar Build Logs 60 09-14-2010 05:58 PM
156 dB No-Wall : Team Sundown Russia sundownz (Sundown Audio) 5 09-07-2010 03:36 AM
