Chrysler 300 trunk wall off - Car Audio Classifieds!
Old 02-20-2012, 10:22 PM
Burbarry's Avatar
Can you hear me now?
0/11 ssssss898
Default Chrysler 300 trunk wall off
Started to build the box and amp rack for a MBquart 4125 and a sundown SAZ-1500 running 3-10" sundown SAs bridged down to .67 ohms.
Here is a few pics:
Box design
Box design
Box cut out
Box almost finished
Hidden amp rack
More pics to come after subs get here.
Sent from behind you!
Chrysler 300 on 24" Menzari's
Alpine 9887 Sundown SAZ-1500 3-10" SAs Walled off
Old 02-20-2012, 10:34 PM
0/11 sssss1286
3 cubes at roughly 44hz?
Old 02-20-2012, 10:44 PM
Burbarry's Avatar
0/11 ssssss898
3cuft but was told 35 Hz.
Old 02-20-2012, 11:13 PM
newarkbeast973's Avatar
0/11 sssss7810
Where is the amp rack going?
New build coming soon!!
Old 02-20-2012, 11:23 PM
Burbarry's Avatar
0/11 ssssss898
Under the subs. Put down rubber under the amps. The stuff you use in your cupboards. I think that should be enough to absorb the vibrations. Also going to put a push pull system with fans in there.
Old 02-20-2012, 11:28 PM
0/11 ssssss542
I used some rubber grommets to isolate the amp, the ones you get from the drawers in the hardware store.
Put one under the feet, one above, a washer one top, then screw it down until the lightly compress.
Old 02-20-2012, 11:41 PM
Burbarry's Avatar
0/11 ssssss898
Might add those as well. Bad thing is I screwed the top board on already. Oh well subs are not here yet, so that makes it easier to get to to.
Old 02-21-2012, 03:12 PM
Burbarry's Avatar
0/11 ssssss898
Picture of amps covered up. Waiying on subs and carpet to get in.
Old 02-21-2012, 03:45 PM
0/11 sssss7810
How tall is your trunk? Lol
Old 02-21-2012, 05:24 PM
knowledge's Avatar
0/11 sssss2548
looks good mang
Chrysler 300 DC audio 15" XL box build Burbarry Build Logs 7 08-03-2011 02:33 PM
Chrysler 300 juancolchado Off Topic Chat 4 04-29-2011 06:52 AM
Joe holiday chrysler 300 black hawk down!!!! JOE HOLIDAY New Member Orientation 25 04-19-2011 06:27 PM
Joe holiday chrysler 300 black hawk down!!!! JOE HOLIDAY New Member Orientation 0 04-17-2011 01:13 PM
Chrysler 300 Build Burbarry Build Logs 5 09-08-2009 04:32 PM
