GMC crew cab install - Car Audio Classifieds!
Old 03-19-2012, 10:39 AM
mcmuffin's Avatar
0/11 sssss3380
Default GMC crew cab install
here we go.
buddys truck he is jd888 or some lame shit on here? ill tell him to post lol
well the build consist of
1- pioneer z2
4- skar vvx 10's
1- crescendo 3500d
1- crescendo 1100.4
1- set of image dynamics ctx 6.5 components front
1- set of image dynamics ctx 6.5 coaxials rear
50^3 milla mat 50 mil
2- ready start batts
lots of 2/0 and 1/0 welding cable
db link rca's
he didnt want to take his back seat out (yes i know) so were putting buckets in the rear and doing a center console all the way down the truck. front dash to back wall.
heres some pics
*** NEW BUILD COMING SOON ***
its a secret for now
Old 03-19-2012, 10:49 AM
jwright0291's Avatar
Big Ballin
0/11 sssss1468
Feedback Score: 23 reviews
Looks good.
Keep us updated
Old 03-19-2012, 11:04 AM
0/11 ssssssss7
Yeah thank to mrs muffin this build is finally gettin done. I had boxes pilled up for months. Hoping to have everything finished by scraping the coast. The truck also has a DJM 4/7 drop on black U2-55 26's, this is also my daily driver so its a slow process
Old 03-19-2012, 11:05 AM
Matt3824's Avatar
0/11 sssss3754
I had this idea the other day. Except I wanted to do like 6 z v3 10s and like 10kw+
Can't wait to see how this turns out
Old 03-20-2012, 02:49 AM
LivinLoud's Avatar
0/11 ssssss524
Looking good so far. When I seen your name as the op I was like he changed his mind once again lmfao
Team Tantric Sounds
2 Tantric Sounds HD 15's
2 Digital Designs M2a's @.5
155.5 outlaw
REF:Loudwhat?,Retroaudioinc, statonburrell,Ho-Audio
well hello fartbox zen master
lol
Old 03-20-2012, 02:56 AM
0/11 sssssss58
MMMMmmm cresendo goodness!
Old 04-19-2012, 03:41 PM
mcmuffin's Avatar
0/11 sssss3380
got the shell built
he wanted to intergrate the stock console in the truck so he had cup holders, storage etc. so we screwed it in there and of course there was a gap at the bottom. but with the pressure of the 10's we didnt now if it would rattle the piss out of the console. so we got a can of expanding foam and foam'ed around the gaps
we obviously didnt want screws showing through the vinyl and the carpet. so everything will be screwed from the inside
we made strips to screw the top on to hold it in place
got the top all cut out, all the angles done and everything sealed. its now ready for carpet. we are using black carpet on the sides and black vinyl on the top. also using 3/4 in padding so its semi comfortable to rest your arm on and so its level with the stock console
thats it for now, ill ger some pics of everything wired up and running. its tuned to 34hz, port is right in the middle of the back seats.
going to carpet her all up tonight and install it, more pics and vids to come
Old 04-20-2012, 12:05 PM
mcmuffin's Avatar
0/11 sssss3380
ok kids, got her all wrapped up but not installed (i know i know) so heres some pics
started off wrapping the sides in black carpet
the black paint u see is spray on bedliner, we sprayed the bottom of the box and corners so if something scrates it then it wouldnt show
All done with carpet
now lets start the padding and vinyl stage. were using 1" padding.
the hardest piece, that goes in front of the consle that has sharp edges
but u know. with me being the shit and all i got it lol
now onto the center peice
DAMN! i did it again!
the last and final peice
i know, the pics suck. lighting was horrible. ill get some daytime pics that will be good
Old 04-20-2012, 12:16 PM
0/11 ssssss267
Looks nice, I expect the down firing from those you will like. Post some pictures of it in the truck.
Old 04-20-2012, 12:19 PM
Matt3824's Avatar
0/11 sssss3754
Looks good. Can't wait to see how it turns out.
The Following User Says Thank You to Matt3824 For This Useful Post:
AltimaGoesBang (05-25-2012)
f250 crew cab subs loondizie52 General Car Audio Discussion & Questions 0 11-23-2011 03:45 AM
Chevy Crew Cab Question??? RetroAudioInc General Car Audio Discussion & Questions 20 05-20-2011 10:32 PM
Crew cab chevy highs linden General Car Audio Discussion & Questions 3 06-25-2010 03:32 PM
Crew Cab Box Pic Request. 350zkid General Car Audio Discussion & Questions 5 03-12-2010 04:56 PM
Crew cab Chevy R/T Pimp Build Logs 1 12-08-2009 10:16 AM
