Time to get loud build. (HOPEFULY) - Car Audio Classifieds!
Old 03-23-2012, 10:20 PM
kickerlivinloud's Avatar
0/11 ssssss162
Default Time to get loud build. (HOPEFULY)
First time doing a build log and not very got at typing so please bear with me.also first time doing a wall.
Build going to contain.
4 MTX 9500 15s Dual 4
2 audioque 3500.1s
pioneer 4300
2 factory 130amp alt's for now
2 runs of 0ga 1 hot/1 ground for now
8 103ah c&d batterys
wall starting at 30 cu ft and then srinking
Old 03-23-2012, 10:33 PM
0/11 ssssss162
almost done caint wait to meter it.
Old 03-24-2012, 12:09 AM
schrummy's Avatar
0/11 ssssss288
you going to round the edges of the port at all
150 db @ 33hz
Team Midwest
Old 03-24-2012, 12:21 AM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
Off to a good start, Rounding the port edges will help you out some, and definatly 30 cubes is a bit much for 4 15s.
Old 03-24-2012, 10:44 AM
0/11 ssssss162
Default Metered it this morning
well i metered it on a audioque 2200.1 at .5 ohm just to see how much gain 1 would get with the aq3500.1
Old 03-24-2012, 10:48 AM
paulcampbell's Avatar
Contributor
0/11 ssssss215
wow, nice work.
30 cubes! watch out for homeless people trying to live in that thing.... keep 'em away with tremendous bass pressure.
Old 03-24-2012, 10:49 AM
0/11 ssssss162
yeah i am going to also going to srink the box brace it and resin it to see how much i cain gain im hoping to get at least get a 158db+ on 2 aq3500.1 straped at .5ohm, .25 each as soon as i get my alts in.
Old 03-24-2012, 11:09 AM
massivespl's Avatar
0/11 sssss8409
build looks good....good luck on 158's,its HARD to get 158+
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 03-24-2012, 11:48 AM
0/11 ssssss162
Default Now metered with the aq3500.1 at .5ohm
a pertty good gain (about 3.2 dbs)but im sure i got a lot more gains left
srinking box
rounding port
bracing baffle (flexing like hell)
resing the box
getting 2 250amp alts
adding the second amp (should gain 3 more db)
Old 03-24-2012, 10:59 PM
2003f150's Avatar
Digital Designs FTW!
0/11 sssss1227
4 9918SC,4 DD M4 @ .25 ohm each 6 NSB 90's,2 NSB130's SINGER 350A ALT!!Flat wall....Scores TBD USACI and Db Drag
The Following 2 Users Say Thank You to 2003f150 For This Useful Post:
kickerlivinloud (03-24-2012), KNOTDUDE (03-30-2012)
$1000/how loud can i make it build sound_around Build Logs 20 11-27-2012 03:23 PM
Skip01....Its time too get loud Skip01 Build Logs 112 11-22-2010 01:36 AM
Box build for loud-n low Ami Creations General Car Audio Discussion & Questions 10 07-20-2010 10:19 PM
Box build for loud-n low Ami Creations General Car Audio Discussion & Questions 6 03-20-2010 07:26 AM
Build me a loud vehicle astrolade General Car Audio Discussion & Questions 34 03-12-2009 01:58 AM
