2006 Lincoln Zephyr Build - Car Audio Classifieds!
Old 04-10-2012, 05:19 PM
0/11 ssssss115
Default 2006 Lincoln Zephyr Build
So figure id start a log on this vehicle here too. Had the car about 2 years but just started the custom install and new eqpmt process in the Fall. Ran the setup off the factory system a while but while the THX system is decent for factory its just not enough. Ive done alot of the work myself but did have a friend build the box and the template sealed in. Started getting stuff done in the trunk now again the last few days. The amps will be eventually switched out but for now i had em so im goin with em. I do work with a local shop so i get new JL almost at cost. So ive gotten this setup done entirely for pretty cheap. Heres what the system will look like in a few weeks:
HU - Kenwood DDX-318 DD 4v subout
Fronts - JL Audio c2 6.5" Component set
Rears - pair of 6x9s not decided yet
F&R Amp - Excelon x600f Four channel
Sub Stage - 12w7 3.0cu ported, sealed into cab
JL Audio 2 ga kit, JL Rca's, 3 2ga fuse holders
SVR800 Battcap
Sub Amp - Excelon X1200M monoblock
Heres the start of it getting the box done and in:
Box built and ready to go in
Box in
SIde piece to mount batt and fuse holders/dist blocks on
Getting the batt mounted
Initial setup
Inside shot
HU - Kenwood DDX318 DVD/Touchscreen 4v
Front Stage - JL Audio c2 6.5" comps
Rear Stage - JL Audio vr 6" comps
Front Stage Amp - Eclipse 2122
Sub amp - Boston GT-28 (900x1 @ 4)
Sub Stage - Hertz 15" SPL d2 @ 3.5cu
Old 04-10-2012, 05:23 PM
0/11 ssssss115
Here are some shots of getting the front comps in
Had to trim out some of the plastic on the 5x7 mount area and door panel
Old 04-10-2012, 05:29 PM
0/11 ssssss115
Heres with the different fuse holders and better coordinated colors
Getting wires sorted for the amps
An idea of how theyll be
Starting to make a template
More back template work
Gettin there
Cutting the rough template on Masonite sheeting
Not a bad fit
Old 04-10-2012, 05:42 PM
0/11 ssssss115
Pulling a 6x9 to make templates (if i put a comp set in the rear instead of 6x9's) or to put in new ones
Cutting templates
Mounting bottom template support
making a template
Rough cut out
ok fit, need to adjust a little
Measuring out some amp windows, will probably do a mesh grille underneath
Heres how the first idea looked
I might consider one large window in case i switch to a 5 channel amp or just narrower windows.
2006 Pontiac G6 Build W/ a RE/Fi Hybrid 12" & DD M3 g6ryder Build Logs 58 06-19-2011 12:27 AM
2006 CRV center console build! andrewtexas123 Build Logs 25 06-25-2010 08:22 PM
2006 Pacifica Build RidnClean Build Logs 48 04-29-2010 05:34 PM
Lincoln LS Build cmwilson Build Logs 7 02-18-2010 05:05 AM
