5 JBL P1224's in a WALL - Car Audio Classifieds!
Old 04-18-2012, 09:24 PM
0/11 sssss1046
Default 5 JBL P1224's in a WALL
Just did this little install at the beginning of this week. Only took a couple of days, but the finished product is better than i expected.
Equipment:
Subs: 5 JBL Power Series 12's
Amps: 2 Kicker IX1000.1's (wired to 1.78 ohms each)
A little back story. So, when i received the truck all looked good. Come to find out 3 of the subs are D4's and the other 2 are D2's. After doing something thinking, i have the power evening distributed to the 5 subs with some tricky wiring. Didn't know if it would work, but finished product is very loud and clean, and all the subs load the same.
Box is 12 cubes with 170 sq. in. of port tuned to 33 hz. Smashes the lows but has a fairly flat response. I know some of you will question the single baffle, but with the 3 2x4 braces inside, the baffle doesn't flex a mm.
With a little tuning, the ear-o-meter is guessing a 146-147. Not bad for ~1600 and 5 entry level subs.
Second time building a wall and i think i covered everything, but if any of you have any other comments i'd really appreciate it.
Old 04-18-2012, 09:31 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
What are the dimensions of the opening of the port?
Old 04-18-2012, 09:33 PM
0/11 sssss1046
37.5 x 4.5
Old 04-18-2012, 09:55 PM
Matt3824's Avatar
0/11 sssss3754
Curious how you wired the subs?
badmofo529's Avatar
0/11 sssss3329
Get rid of the d2's
Sent from my inspire 4g using tapatalk
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 04-18-2012, 10:08 PM
0/11 sssss1046
Each amp is seeing a D2 sub wired in series, a D4 sub wired in series and 1 coil of a D4 sub, all of these wired in parallel. Each amp is seeing a 1.78 ohm load.
Old 04-30-2012, 01:55 PM
0/11 sssss1046
Metering this setup on Sunday in Guthrie, OK. We'll see what it does.
wall guys help please. single psi 15 wall or not? blk1990gt Enclosure Discussion & Design Construction Help 1 04-18-2012 09:39 PM
WTB blown jbl gto1400.1 amp or jbl gto750.1 amp. for parts .. kickerfanatic Wanting to Buy (WTB) 1 03-16-2011 09:41 AM
Made in USA JBL W10GTi top dog JBL 600-3000 power handling gentlejax2 10" Subwoofers 9 02-25-2011 06:12 AM
