07 Harley F250 and two FI 18's (pic heavy) - Car Audio Classifieds!
Old 04-23-2012, 12:32 PM
SWIFT's Avatar
0/11 ssssss656
Default 07 Harley F250 and two FI 18's (pic heavy)
I currently have a 15in Q on a SAZ1500v.2 in a box I designed and built that is a rear center console in my truck. It hammers the lows and the output is simply amazing for only one 15 but its time for something bigger.
Here is the truck it is going into
2007 Harley Davidson F250, 6.0 diesel, 3in lift, 20in Rockstars and 35in Nitto Trail Grapplers. This is my daily driven work truck.
Here is the current full list
Power and wiring
Big 3 done and all 1/0 KNU OFC
2 Optima Red tops,
*Monster Cable... Slim battery terminals
Stock alt
*Tsunami main fuse holder up front and distribution fuse box for back.
*Kicker ground block
*KNU 10 gauge speaker wire for sub, 16 gauge for speakers
RF rca's, etc
Head Unit
Alpine IVA-W200
NVE-N872A
KCA-100BT
Sub, box and amp
*one 15in FI Q, cooling option and extra spider
*3.65cu ported console box tuned to 29hz
*Sundown SAZ 1500D v.2
Speakers and amp
Rockford T-2652s Components up front
Alpine Type R 5x7 rears
Alpine PDX 4.150 (love this amp)
Here is the my progress so far
Space I have to work with, this stuff has already been removed and floor is being built now
power
head unit,
Equipment going in will be
two 18in FI Q's, dual 1ohms, cooling and extra spider options.
Crunch GP3000-Pro
Mechman 270 alt
2 XS D3400's
Here are my progress pics
Box specs are 14.2cu tuned at 31hz
Subs forward on driver side and port up on pass side
All double layered 13 ply Russian Baltic Birch (5 sheets used)
Cuts done
Predrilled
adhesive spread, no board slap here
Got bracing
All edges rounded and flushed
Box came out to be 14.2cu tuned at 31hz with 204sqin of port, (14.36 per)
I love the sound of the Q's and the lows should be quite brutal with this setup "I hope".
Now I just need to carpet it and will be doing a 1/4in panel in leather for the front to match up with my interior and give a partial flush mount look.
Gotta get my amp placement done and hopefully my subs will ship soon.
Old 04-23-2012, 12:41 PM
SOUND SPECIALISTS
0/11 sssss2315
Feedback Score: 46 reviews
Man that looks great, wish I could hear it in person. Nice truck too.
Car: 2001 Chevy Silverado
Deck: Alpine -9833
Subs: 2 Atomic AP10's
Mids: Atomic components
Amps: Shok II and Shok 100x4
Old 04-23-2012, 12:51 PM
sherrod833's Avatar
0/11 ssssss602
Feedback Score: 21 reviews
Nice bracing.Box looks solid
Old 04-23-2012, 01:34 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
What's up heavy
Truck looks great and so does the box man. I need to hear this! You may be louder than me!
Old 04-23-2012, 03:15 PM
SWIFT's Avatar
0/11 ssssss656
Originally Posted by jt_buck View Post
What's up heavy
Thanks, yeah anytime. Not looking to get louder than anyone just to sound good. But I think it will get down pretty good when done. I will probably get the subs broke in on the 1500 till my alt gets here.
Old 04-24-2012, 04:42 AM
CHRIS 323's Avatar
0/11 sssssss56
nice truck
Old 04-25-2012, 08:47 AM
SWIFT's Avatar
0/11 ssssss656
Got the false floor done last night. The uncovered portion will be covered by the box so I didnt waste carpet.
The front panel has 4 screws that hold it on so I can access wiring. Amps will be placed on front top side after the box is put in. Will make for easy adjustments and should look decent.
Old 04-25-2012, 04:33 PM
0/11 ssssss195
Nice looking truck, good looking box too.
Old 05-04-2012, 12:50 PM
SWIFT's Avatar
0/11 ssssss656
Little progress here.
Finished sanding down all resin on box, entire inside is smooth now. Got the carpet done, not real concerned with seems on sides because leather beauty panels will cover sides and front. I will probably use velcro for those.
Sorry for shitty photos, everything will clean up much better when done.
Here is finish box ready to go in
Took 3 of us to get the box in place after we had to completely remove the rear door from hinges, lol
5/16 terminals on side
Port clearance on pass side
Amps and ANL distro Block will be mounted in front of box, \
Subs finally shipped from FI and are on the way. Gonna do the leather panels tomorrow.
I will get everything wired up and mounted this weekend a so all I have to do is drop the subs in when they get here.
Old 05-04-2012, 01:08 PM
0/11 ssssss466
i need to nut up and take my backseat out now! Nice truck!
whatheissayingisthatyoursentencestructureandgramma risshitandyouneedtoleantopunctuateandmaybegotothel ibraryandcheckoutanenglishbookormaybestopasecondgr aderonthestreetandaskhimtoteachyouhowtotypeandorge tyourpointacrossinthewrittenwordbecausenobodycanco mprehendanydamnthingyouaretryingtosay
The Following User Says Thank You to ThatChevyGuy For This Useful Post:
150orbetter (01-11-2013)
77 GMC Crewcab 1 ton Dually - stock floor body drop - bagged - pic heavy ampjunkielikeme Miscellaneous Build Logs 32 08-15-2012 12:24 AM
Harley Davidson collectors [email protected]@k mdaudio Off Topic Chat 3 02-01-2012 07:36 PM
85 f250 with jbl Tom58c Member Rides & System Pictures 0 06-12-2011 03:35 AM
05 Ford F-250 Harley Davidson Edition Build Ami Creations General Car Audio Discussion & Questions 85 12-29-2010 10:06 PM
Harley Earl GM Turbine Cars ~ Hershey PA ~ 09-27-2008 Patrick Simmons Car Show Feeds 0 09-22-2008 03:02 AM
